First two years of Toyota care
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ETP, Jun 29, 2020.
  1. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Are air filters included? Thought I read they were but the dealer said no!!!!
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Could be because they are not scheduled within the first two years/24K miles. You're better off staying away from the dealer anyway. Just order the filters from Amazon and change yourself. Simple DIY.
    dig4dirt likes this.
  3. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    I would honestly rather change the air filter myself. I like to see the filter instead of them just suggesting to have it changed. I have heard some shops keep a dirty air filter around and then show it to customers to persuade them to change it. With that said, I doubt dealer would suggest a "free" air filter change when most of the charge $50 to change it.
  4. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Only scheduled maintenance items for normal use are included in the Toyota Care. They will now do additional recommended maintenance items even if you condition is severe. Air filter is not included in the schedule in the first 2 years. Basically rotate tires and check fluid level and top off if needed and visually inspect brake pads plus oil and lube (only twice).
