Fitting a new Toyota HV batt - any tips please
Discussion in 'Gen 2 Prius Main Forum' started by Scottyx, Jan 4, 2020.
  1. Scottyx
    Scottyx Junior Member
    92
    40
    Sydney Australia
    ----Australia----
    Hello
    I have ordered a new HV battery from Toyota and will pick it up in a day or two.
    Does anyone have any tips or advice please?
    Maybe things to avoid.
    Thanks for your time
    Scott
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Don't return the old battery until you've moved over all the bit and pieces onto the new battery.
    jerrymildred and Raytheeagle like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,412
    5,414
    Pacific Northwest, USA
    It's quite an easy process... Study up on where the ECU, relays and wiring part of the battery pack is. You're going to be using your existing one and that metal box is simply mounted to new chassis that comes with the new modules, chassis and bus bars already assembled. Two hours or less work once you've done it once.
    Do lots of deep cleaning of your car before you get started and then once you have the car taken apart do even more cleaning, especially the hybrid battery cooling fan, which you should give a good scrubbing to.
    As for taking the car apart, making the swap and putting the car back together, this dude did it in less than 13 mins once... He knows every trick in the book to making it go super fast:
    SFO likes this.
  4. Scottyx
    92
    40
    Sydney Australia
    ----Australia----
    Cool, thanks
    I pulled the old battery out quiet easy with you tube video instructions.
    Once I get the new one are you aware of anything to do like checking charge or something before I put it in?
    The video I used yesterday goes for about another hour so I will also watch that.
    Just trying to make sure I don’t make a stupid mistake.
    Have a good one
    Scott
  5. PriusCamper
    13,412
    5,414
    Most dumb mistakes are related to plugging the orange safety plug in too soon... This is a brand new pack, so no need to test electrically, just visually, to make sure there's no damage.
    Also you might consider showing up with your existing battery pack with ECU-relay box already removed and making sure the person responsible for inspecting core deposits is working at the time you arrive.
    That way you can get you core deposit expedited as quickly as possible.
  6. George W
    George W Senior Member
    937
    520
    San Antonio
    Actually, this dude takes way too many shortcuts AND tears his back muscles in the process(he says so in the video). Maybe watch as the way NOT to do it.
    strawbrad likes this.
  7. Scottyx
    92
    40
    Sydney Australia
    ----Australia----
    Toyota don't want my old battery. I think they said cause it's over 10 years old or maybe 8 years was the limit.
    donbright likes this.
  8. Scottyx
    92
    40
    Sydney Australia
    ----Australia----
    G'day George
    The video I was using is about 1hr 20min. It's good because the dude making the video is so easy to follow and at an easy pace so I'm not pausing every 10 seconds
  9. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Did you have to pay the HV battery "core charge" (deposit) ?
  10. Scottyx
    92
    40
    Sydney Australia
    ----Australia----
    I’m not sure. But I guess I did.
    It cost $2430. If you bring back a suitable battery they refund you about $500.
    My battery is too old for them.
  11. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    You might want to call Toyota corp and ask about this, as this could be shenanigans on the dealers part.
  12. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    That AU$2430 is roughly equivalent to US1688, so I'm guessing there is no core fee added. I suspect that if they wanted the core they would have added on $500 to be refunded on return of the core.
    Interested to understand why they have an age criterion on the old battery.
  13. strawbrad
    953
    1,007
    That old battery is just a bunch of work for the dealer with no money in return.
  14. George W
    937
    520
    San Antonio
    Or now that there are cheaper alternatives, Toyota recognizes they are no longer the Monopoly
  15. Scottyx
    92
    40
    Sydney Australia
    ----Australia----
    Picked up the new battery today, put it in and the car fired right up.
    I'll take it for a test drive tomorrow.
    donbright, fotomoto, SFO and 2 others like this.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I'm curious. Australia is certainly different when it comes to core fees, lol. Did this battery come fully assembled? Did you have to remove the electronics portion from your old battery and install it onto the new one? Just reading your post fairly quickly, it almost sounds as if it was just "drop it in and go".
  17. Scottyx
    92
    40
    Sydney Australia
    ----Australia----
    I had to remove the electronics portion from my old battery and put it on the new one.
    And no core fee because the battery was too old for Toyota.
  18. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Is that what Toyota of Australia told you?
    Contact Us | Toyota Australia
  19. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Every battery I've ever done for Toyota in the US requires return of core. No matter the mileage or age.
    Biggest mistake folks make when reassembling is not properly torqueing the nuts for the battery posts and High Voltage contactors. As long as you used a torque wrench to tighten them you should be fine. If you simply guessed, well, cross your fingers and hope for the best. Personally I wouldn't take that risk.
    It's a good idea to clean the hybrid battery fan while you are back there as well.
    donbright and jerrymildred like this.
  20. Classic Car Guy
    Classic Car Guy Active Member
    501
    135
    Northwest, USA
    No wonder Kenny Rogers is been out of the loop. He's been busy. :)
    tonynap likes this.
