Fitting mobility 12volt AGM battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Britprius, Mar 3, 2013.
  1. 2007blueprius
    2007blueprius Member
    466
    33
    oh I found the fineprint at the bottom of the page large one 36 AH, small one 28AH, but they do have a brightly colored top, and they are just as pricey as the toyota ones.
    man I could have bet money on this one, I knew it, but waitttttttttttt It comes with a 6 page instruction manual free, but you must call now, and they ship next day, cant get rid of them fars enough.
    My god, to those that like things like optima, I mean the brightly colored kind you see on tv all the time, ask somebody that has a clue before you buy
  2. 2007blueprius
    466
    33
    hey john , I do have a question for you :
    Why do you seem to think a 10 hour cycle is different than a 20? I thought, 5.5 amps for 10 hours, or 2.75 for 20 is still 55 ah, just curious, 55 ah is good for me regardless, but you must know something I dont.
  3. Patrick Wong
    18,210
    6,517
    It is easier for a battery to produce a high Ah rating over a 20 hour cycle vs. a 10 hour cycle since it only has to produce half as much current flow over the longer period. The battery has internal resistance which results in some of its chemical energy turning into heat as electrical energy is produced. The heat loss is proportional to the square of the current flow.
    A derivation of Ohm's Law results in this formula: I^2 x R = P
    where I = current, R = resistance, and P = power
    Ramanjit81 likes this.
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Thanks Patrick. What this means in simple terms is, the faster you discharge a battery the lower it's useable capacity will be. Conversely the slower you discharge a battery the greater it's useable capacity. Google "Peukert effect" to learn more.
    John (Britprius)
  5. 2007blueprius
    466
    33
    I kindof was suspecting the same thou that class I missed in school, thanks for the refresher,
    jacques1 likes this.
  6. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    Ok , now that my head is spinning after reading all of this , I did a google search for the Ritar 12-55 battery and it directs me to a repacement for the Ritar battery , is this one ok for a 2006 prius ??
    Home > Sealed Lead Acid Battery (AGM) > Ritar > 12V 55Ah > Amstron 12V / 55Ah Battery - NB Terminal (BCI Group 22NF) for Ritar 12V 55Ah Battery
    Alternate Views
    [​IMG][​IMG]
    SKU: AP12-55 (CR# 453947)
    Brand: Amstron
    Genuine Amstron. Brand New
    Amstron AP12-55 has been cross-referenced to be compatible and replace Ritar 12V 55Ah sealed lead acid Battery. This 6 cell battery by Amstron is rated at 12V 55.0Ah 660 Whr.
    Specifications
    Chemistry Lead Acid
    Voltage 12.0 V
    Capacity 55 Ah
    Rating 660 Whr
    Cell 6 cells
    Connector NB
    Certifications ur,ce
    SRP:
    $189.99
    OFF SRP: 17%
    Our Price:
    $157.99
    Save Extra 10%:
    -$15.80
    Price: $142.19
    Availability: In Stock
    Free Ground Shipping with $75 and over
    Same day shipment
    30 days money back
    AA miles on every two dollars spent
    24 months warranty
    DescriptionCompatibility ChartReviewsEstimated DeliveryTech Support
    Amstron 12 volt 55Ah valve regulated sealed lead acid batteries are maintenance free, rugged and economical. Amstron SLA batteries are utilized in a wide variety of applications including electric vehicles, wheelchairs, scooters, UPS backups, computer systems, industrial and medical equipment and more.
    Delivering power when you need it, the AP12-55 uses a state of the art, heavy-duty, calcium-alloy grid that provides exceptional performance and service life in both float and cyclic applications.
    • Absorbent Glass Mat (AGM) technology for superior performance
    • Valve regulated, spill proof construction allows safe operation in any position
    • High energy density
    • Approved for transport by air.
    • UL recognized under file number MH47341
    71 Compatible Model Numbers.
    Specifications
    Chemistry Lead Acid
    Voltage 12
    Capacity 55000 mAh / 55.00 Ah
    Rating 660 Whr
    Cell 6 cells
    Connector NB
    Length 9.04 inch / 22.96 cm
    Width 5.45 inch / 13.84 cm
    Height 8.15 inch / 20.70 cm
    Color Black
    Weight 39 lb / 17.69 Kg
    Warranty 2 Years
    UPC Code 880487226595
    PDF Downloads (1)
    [​IMG] specsheet_AP12-55.pdf
    Compatible Models
    Ritar 12V 55Ah
    Compatible Part Numbers
    Ritar RA12-55 Ritar RA12-55H
    Compatible Brands (Select brand to view models)
    Amstron (4) BB (1) Casil (1)
    CSB (3) Deka (2) Douglas Guardian (2)
    EnerSys (3) Fullriver (1) Hawker Cyclon (4)
    Haze (1) IBT (2) Interstate (19)
    Johnson Controls (5) Kinetik (1) MK (1)
    Power Patrol (1) Power-Sonic (4) Rhino (1)
    Ritar (3) Shuriken (2) Sonnenschein (2)
    Tempest (1) Union (1) Universal (UPG) (2)
    Vision (1) Yuasa (3)
  7. Britprius
    5,194
    1,922
    Paphillyman, Yes that battery will fit. It is a slightly lower capacity than the Ritar and I am unsure if that battery is vented, but it will fit the application in the Prius.
    John (Britprius)
  8. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    should the battery be vented?? would they know if the battery is vented if I call them . I did call batterysharks and the guy didnt think the battery would be right for a Prius .
  9. Britprius
    5,194
    1,922
    The OEM battery is vented as are all agm batteries, it's realy a matter of being able to pass the gasses if any produced by the battery to outside air. The origonal Ritar battey is supplied with a vent tube, so if it's being advertised as a Ritar replacement so should the battery they are supplying, if it is not with a vent tube it is not a suitable Ritar replacement.
    The lack of, or availability of a vent tube does not in any way alter the operation of the battery but some quite understandably are not happy to use a battery without. This must be your decission if you cannot find a battery with a vent tube.
    The OEM battery is an AGM battery as are the mobility batteries and the charging requirements are the same. The Prius does not have a conventional 12 volt starter motor, so does not require a starter battery, and does not have an alternator. The question must be asked how much does the "battery guy" know about a Prius. Does he know these facts, most non Prius owners and a supprising number of owners do not know or understand the workings of the cars.
    John (Britprius)
  10. srivenkat
    srivenkat Active Member
    596
    93
    IL
    As I mentioned earlier in the thread, Mastersafe by Ritar might be worth looking into:
    RA12-55 - 12volt 55a/h - Sealed lead acid battery for UPS and Telecom, RITAR RA12-55 RA1255 - xpressBatteries.com
    Actually, the above is shown to be a "Ritar" battery (55AHr at 10Hr rate) being sold alongside other "Mastersafe by Ritar" batteries. Plus it seems to be cheaper than the one you asked about. Might also have the vent tube provision...
  11. Britprius
    5,194
    1,922
  12. ls40095
    ls40095 Junior Member
    61
    Only in America can you buy a wrecked Prius for a few grand, partially repair it and tour the USA for nearly 6000 trouble free miles!
    No issues with the battery whatsoever!
  13. dr_d12
    dr_d12 Member
    154
    If you’re in Canada looking into Gen2 battery options:
    Dealer
    32Ah large w/smart-key battery (dealer quoted $203)
    (I didn’t check the price of the smaller 29Ah non-SKS battery)
    www.saskbattery.com
    38Ah Optima Yellow Top for Prius ($185 shipped). It has the right terminals and uses the stock vent tube.
    www.batteryspecialist.ca
    45Ah Exide Edge (Group S46B24R) FP-AGM51JIS for Prius ($145 + 35 shipping). It has the right terminals and uses the stock vent tube. They also have a good price on the Battery Tender Plus.
    Mobility
    I found many U1 and 22NF mobility batteries at Saskbattery.com Optima battery, odyssey battery, Deka battery, rebuild drill batteries, inverters, , SLA-Sealed Lead Acid Batteries - 12 Volt SLA Batteries - Battery Specialist, Battery Buyer - Batterybuyer.com, etc.
    All of them have flag terminals and would need a bolt-on adaptor to the Type A3 JIS Pencil Post, or modification of the car’s hookups. I was not able to find similar batteries with threaded terminals. All that I have seen have slot-vents that would need to be modified if you wanted to continue using the Prius vent tube.
    Non-SKS Prius?
    If you have a non-SKS Prius, your options are Toyota OE or Group U1. Other posts say that the Optima will tightly fit into the smaller battery tray, perhaps with a lopsided clamp or longer bolt?
    To increase Amp-hours with an S46B24R or 22NF battery, you need a “battery tray 12 volt w/”smart key”, which the dealer sells for $26 (much cheaper online in the US, as usual).
    Cheers.
  14. jacques1
    jacques1 New Member
    Yup same here.
    Earlier i was also wondering for fitting mobility 12volt AGM battery matter but now it seems that ending time is come.
  15. SubPrius
    SubPrius Junior Member
    31
    Decades ago, I worked with industrial grade lead-acids. There were drip pads of loose woven fabric that was filled with what I recall was baking soda (real high tech - real cheap).
    Does anyone know if: it was baking soda, and whether a drip pad would be a prudent measure in a Prius?
    BTW, PriusChat is MUCH more mature and at least semi-professional and beyond.
    In other forums, this thread would have gone nuclear at the first question of bona fides.
    I wonder if that is related to the average age of the forumites?
  16. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    So long as you've got your vent tube properly attached and routed, I don't see a need for that.
  17. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Has any body ever opened up a Toyota batt. to see if the vent is actually functional.
  18. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Yes, I have; and yes, the vent is functional on the original battery.
  19. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Thanks. I want to replace the original 08 Prius batt. But the only one available in my area is a UB 12550 12 V 55 AMP which has no vent hole. BUT, I see no need if it is a SEALED agm batt.
  20. bobodaclown
    bobodaclown Member
    216
    72
    I just did one. No vent tube. Sealed AGM. It was $115. I did swap out the battery mount. It wasn't as clean I would have hoped but it's working well after only a week.
