Fitting mobility 12volt AGM battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Britprius, Mar 3, 2013.
  1. Albert Rozsalyi
    Albert Rozsalyi Junior Member
    Toronto
    My first post on priuschat. Last winter, in Jan 2016, I had to replace the battery in a 2008 Prius and thanks to this thread that I could do a quick research and find a Ritar RA12-33 compatible battery in my area Toronto, Ontario, Canada.
    After almost one year I can report back that the battery works fine. I can't post the link but those interested can find the small battery shop by searching upsbatterycenter
    m.wynn, tvpierce and bisco like this.
    52,852
    well done, thanks for the update!(y)
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I sincerely hope you never need the safety features that the correct replacement battery has.
  4. Albert Rozsalyi
    Toronto
    I remember one year ago how surprised was the owner (Anton K.) of the battery shop when I showed up at his door and I told him that I'm looking for a Prius battery :))))) Lucky me I had a print out of this thread so he didn't think that I'm crazy.
    He kept telling me that he thought that he knows everything about batteries but never thought that one of his batteries could fit a Prius :)
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The Rittar battery has all the "safety" features of the OEM battery, but does not rely on a piece of sticky tape to seal the top of the battery. The mobility batteries are designed to be safely charged inside peoples homes, and indeed hospitals being fully RoHS compliant.
    John.
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Great information. Thanks John!
  7. R-P
    R-P Active Member
    808
    288
    Netherlands
    9 weeks of not using the Prius (standard small battery replaced by 55Ah AGM in 2016). Started right up!
    Only used it to drive 10m across the public parkinglot to be close to my garden (=powersocket) and the 3.8A (3, 4, 5? stage) charger took somewhere between 12 and 20 hours to fill it up again (finished somewhere during the night). 12.2V when I started iirc, but this was AFTER the 10m drive, so after the 200=>14V inverter had charged it for half a minute.
    Britprius likes this.
  8. Britprius
    5,194
    1,922
    Having sold my Prius. I am now the owner of a Lexus GS450H hybrid, and have removed the OEM 90 AH battery. It has been replaced by a 120 AH "mobility AGM" battery of the same physical size. The battery in the Lexus is mounted in the boot "trunk I believe in the US" in much the same way as the Prius.
    The Lexus having things like heated seats, the ability to play DVD's in the 6 CD changer with front and rear screens, and 17 speaker Mark Levinson surround sound system. All of which can be used while in accessory mode needs a battery with substantial reserves.
    John
    SFO, lucaspiller and R-P like this.
  9. csutton7
    csutton7 Junior Member
    Spartanburg, SC
    If you're looking for an "off the shelf" quick and cheap solution, the solar batteries from Harbor Freight will work. It's only 35A, but will do. Normally $70, you can get them on sale occasionally for $50. Standard hardware will work, just have to attach in a little different way.
    R-P and milkman44 like this.
  10. kilimar
    kilimar Junior Member
    51
    That's in interesting discovery. The 12V 35AH battery sold at HF is sold with and for solar application. It is interesting to note that the user manual states, "Avoid over-discharge and deep discharge." Reading the user reviews, it seems that like many (but not all) items are HF, it is of low quality and the 35A maybe over rated.
    I just discovered this thread and was looking for Ritar brand batteries here in the US but it seems that they aren't available. All I can find are "Ritar replacement" or "Ritar compatible". I'd like to avoid crappy compatible ones. Can anyone recommend some (with model numbers) that are readily available in the US (and fit properly).
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    None of these batteries will fit off the shelf, The Prius uses JIS posts which are rare in the US. Your passengers deserve externally vented, AGM batteries. (If you never have passengers, then the scarring is not our concern) The correct buzzword for the right battery is S46B24R. Many vendors exist, most auto parts chains have one.
  12. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    There are a bunch of similar AGMs for sale in the states, but not the Ritar brand (n)
    All of the others that I've found so far are a .1 (tenth) of a inch shorter, and 3 lbs (of lead?) lighter.
    Ritar does appear to be doing business with OEMs in the states, but not with their own branding.
    They must be private labeling for someone ?
  13. JenniferG
    JenniferG Junior Member
    US
    I created an account just to thank John and to share my experience with replacing the 12V battery on my 2011 Prius. I bought the car used about a month ago, and it was sometimes failing to go to "ready." I was able to eventually get it to start by holding the power button for 5-10 seconds. Internet research revealed that it was probably the 12V battery, which I tested with an analog multimeter. It was somewhere between 9 and 10 V. Having found this thread, I ordered a 35Ah Keyko battery from Amazon for $79 shipped (KT-12350 HRT). They also make a 55Ah battery, but it is ~1 inch taller than the battery in the car, so I didn't want to risk not being able to install it. This one was shorter than the original, but I put a piece of 2x4 (which is 1.5 inches thick) under it and the height was then perfect. The part that I was the least confident about was connecting the L2 terminals, but they fit once I spread the jaws of the connectors out a bit, and when I clamped it all down they felt solid. On the positive terminal, my car has a plastic shield, which I had to open up (there is a hinged bit that can be pried up with a small screwdriver). But it did all go back together, once I had tightened the connector over the terminal. the connector bit into the terminal at the corner, and so the terminal molded into the right shape.
    I did look for vents to try to rig something up, but don't see them. But I've tried to collect hydrogen gas created during hydrolysis for a teaching demonstration, and even collecting it under water, it can be hard to ignite it. So I'm not worried about it.
    So thanks for the thread. It's starting the car quickly and I'm glad for the learning experience. I have a few pictures of the terminals in case they might help someone else
    ETA: You will need 10mm and 12mm sockets on a socket wrench. All the bolts are 10mm except the one on top of the positive side, which is 12mm.
  14. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I've had one of these unsafe KILLERS in my Prius for over three years and not a fatality yet. I've posted it somewhere on PC before, don't remember which thread. I installed it the same as yours and used a 1 and 1/2 in. block of wood on top and it's as secure as the original, just lighter and lots cheaper.
    UPG 12V 35AH Group U1 Deep Cycle Sealed Battery | eBay
    SFO and m.wynn like this.
  15. audiodave
    audiodave Active Member
    800
    272
    US
    Nice to see such a high voltage with the head lights on.
    Ramanjit81 likes this.
  16. Britprius
    5,194
    1,922
    I do not post here very often now as I no longer have a Prius having bought a hybrid Lexus. So I am still keeping the faith with the system, and manufacturer. I do look in occasionally to see what old friends are doing.
    It's good to see people going the route that I took with mobility batteries. In my Lexus GS450H I have fitted a 120 AH version since the car is power hungry having heated seats, and the ability to play DVD video while parked.
    To everyone have a great Christmas, and happy new year.
    John (Britprius).
    rbdigital, milkman44, bisco and 3 others like this.
  17. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I thought about using one of these batteries when I found out the Prius battery was AGM. One thing that concerns me is making sure there is enough surface area contact with the cables to the terminals, a few of the pictures I've seen look a little sketchy. With the OEM round posts and the round clamping cables there is a solid connection. Has anyone found a good way to connect the cables providing a contact area equivalent to the OEM setup?
  18. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I wouldn't be at all concerned with the contact area. Think of the small contact area you have when using jumper cables to start a conventional car/truck. That relatively small contact area is carrying huge current loads -- well over 100 amps constant, and double that for the initial surge.
    However, you can never have too much current capacity. So these might do the trick. I don't know how they would affect vertical fitment.
    SFO likes this.
  19. Britprius
    5,194
    1,922
    I think you are missing the point that the 12 volt battery in the Prius does not carry engine starting current loads as with other normal cars. The Prius as such does not have a 12 volt stater motor. This job is done by the electric drive motor in the transmission powered by the HV battery.
    John.
  20. bisco
    52,852
    nice to hear your voice again john, i hope you have a wonderful 2018!
