Fitting mobility 12volt AGM battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Britprius, Mar 3, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    I have no reason to expect this type of battery not to be superior against the OEM and Optima at a far better price.
    You have to bear in mind that the Prius battery is a very limited market, part of the reason for the huge mark ups. The dealers make more on replacement parts and services than they do on sales of new cars.
    The number of electric wheel chairs and scooters in use world wide is enormous and there are two batteries in every unit. This means they are made in large numbers.
    Because of the applications involving disabled people these batteries have to be reliable, safe, have longevity, and the ability to withstand abuse both electrically and physically.
    John (Britprius)
    Fostel, Ramanjit81 and SteveLee like this.
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Is this a typo? Like, you have no reason NOT to expect this..?
  3. Britprius
    5,194
    1,924
    Yes thanks changed it.
    John (Britprius)
    Ramanjit81 likes this.
  4. Britprius
    5,194
    1,924
    The smaller battery RA 12-33 at $70 based on $200 from the dealer would be close to 1/3 of the price.
    John (Britprius)
    Ramanjit81, kithmo and usnavystgc like this.
  5. SteveLee
    645
    180
    North Carolina
    I
    Then I believe your discovery of the use of the mobility battery, being superior to the OEM and typical replacements in expected life at a far better price, is a very welcome contribution to the Prius community. Thanks John.
    Genghis John likes this.
  6. Britprius
    5,194
    1,924
    These batteries are also suitable for UPPS power supplies, wind and solar energy, and even fork lift trucks. They are made in capacities from 26 AH to 3000 AH.
    John (Britprius)
  7. SteveLee
    645
    180
    North Carolina
    I
    I can see they would also benefit solar charged battery powered outside night lights. In what applications would they not be suitable?
  8. Britprius
    5,194
    1,924
    They are not really suited to vehicles with starter motors and alternators giving out 15 volts+ at 80 to 100 amps to recover quickly from the discharge of the starter. They will work but will be dried out by the high current leading to an early demise.
    The RA 12-33 is 9.9 amp max charge rate and the RA 12-55 is 16.5 amp max. The Prius only charges at 4 amp max and is designed to charge AGM batteries. In an emergency it is ok to charge AGM batteries with an ordinary lead acid charger as a one off, Some chargers have an AGM setting and it is safe to use those or specific AGM chargers.
    John (Britprius)
  9. SteveLee
    645
    180
    North Carolina
    I
    John, what has been your experience with the effect on cycling of the ICE? Does it retain a charge longer or shorter period of time resulting in the ICE running more or less often. I guess what I'm asking is did you notice any change in MPG in your car with the battery change?
  10. Britprius
    5,194
    1,924
    I cannot in all honesty say the battery has improved fuel consumption, it has not gone down either, but a bad battery can and does cause MPG drop as the HV battery continually tries to charge a battery that will not hold a charge.
    I changed my battery as a preventive measure and because I am having an electrically powered system installed to load my electric scooter requiring a good battery,"no use loading the scooter the finding the car will not run because the loading gear had used up the battery".
    I also at the time of change needed a new battery for my sit and ride mower so the Prius battery ended up there, saving all round.
    John (Britprius)
  11. SteveLee
    645
    180
    North Carolina
    I
    So this battery is pulling double duty then? The scooter loading system runs off the car battery? Do you use any kind of solar charger or carry a battery jump starter just in case? Do you carry an inverter to run a charger for the scooter?
  12. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    Great discussion... So happy we're talking about facts rather than the usual close-minded Optima-supporting fear and loathing of something different routine!
  13. Britprius
    5,194
    1,924
    Yes the loading system runs on the car battery. I do not use a solar charger or carry a jump start battery.
    I do not need to charge the scooter during the day as it last for the day and is charged with cheap electricity at night. If I am going away for more than 24 hours I take a mains charger with me.
    I could if needed jump the car from one scooter battery, but the whole point of the exercise was to make things reliable and easy to operate on my own. For example if the system cannot unload the scooter because of a flat battery I would not be able to get at the battery.under the floor with the scooter on it.
    John (Britprius)
  14. SteveLee
    645
    180
    North Carolina
    I
    Yes, it has been a good discussion because of the facts that John started with in this thread. I agree, it helpful when we stick with facts.
    PriusCamper likes this.
  15. Rich12
    Rich12 Member
    176
    29
    Wanker!
    Awesome... Was wondering why this discussion was so troll-free? Welcome to the discussion Mr RichWanker. Do you have something to offer to this discussion? I sure hope so!
    I did see a few Personas on the lot in Roseville and they look great. Something about those upgraded rims make the car look so much more luxurious and sporty.
    After searching further, the Prius Persona in Blizzard Pearl is what I want. The black cherry is pretty nice too, but the Blizzard is the safer bet.
    Also, when I see delivery fee listed on cars...do people always have to pay those?
  16. Britprius
    5,194
    1,924
    This from someone that believes an Oddesey 18 AH battery with the wrong terminal layout is the perfect battery for the Prius, and have you seen the price.
    John (Britprius)
  17. boppo
    boppo Active Member
    799
    139
    Owego, NY
    The is a awesome post, I think this will be my next battery.
  18. PriusCamper
    13,467
    5,436
    A Prius puts so small of a load on a 12volt battery that its quite likely even the worst battery would work just fine. I mean how many people are driving around with Optima batteries that barely even function as real batteries and they swear by how great they are simply because of how much money they were tricked into paying, and besides the Optima has pretty circular parts and a bright yellow-top. If that isn't proof of value, well perhaps most people don't know what value is! :)
  19. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Just googled "ritar ra12-55" and found it is a company based in China:
    Ritar : About Ritar
    Google did not return results on where we can buy the battery, but many results of replacement batteries. I guess it is made mainly for OEM purposes. If someone finds a US retailer please post. Thanks!
    SFO likes this.
  20. ls40095
    ls40095 Junior Member
    61
