Five w/ A.T. package vs Plug-in Advanced?
Discussion in 'Gen 3 Prius Main Forum' started by beavis87, Dec 15, 2017.
  1. beavis87
    beavis87 Junior Member
    23
    El Paso
    Leaning more toward the Plug-in Advanced. It seems like its a Five with Advanced Tech package with a charging port, different wheels, adaptive cruise control and what else? I've heard it has a different battery? Is it any better or worse than standard batteries? What should I look out for now that there is a recall on a fuse? I don't have access to a charging port since I live in an apartment, will it be bad if I don't plug it in every night?
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Five W/ATP has lane keep assist. plugin advanced does not.. Self parking is in 2010-2011 but missing in 2012-up and the plugin
  3. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    Right, I wish they had kept Lane Keep Assist in the new model. Lane Departure Warning is useless.
    Prodigyplace likes this.
    52,807
    lion battery instead of nimh, that's good, and much larger of course. no need to plug in at all, that won't hurt it.
    you lose the spare tire, and the storage under the rear deck.
  5. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Snoop around a bit. You might find an outlet nearby. Is there place you frequent often that might have an available outlet? Checkout plugshare.com to find local chargers and outlets.
  6. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Actually there is storage under the rear deck. It is smaller but deep and narrow.
  7. beavis87
    23
    El Paso
    Dann not having a spare tire is worrisome. Guess I got to have great roadside assistance. I'm a mechanic so not being able to fix something simple and waiting for someone is embarrassing. I guess for road trips I can just throw a spare tire in the back and take it out for daily driving in the city.
    VS995 ?
  8. Mendel Leisk
    42,305
    Roadside assistance can't do anything you can't do. If the tire is repairable, it ends up being a tow.
  9. beavis87
    23
    El Paso
    Yes its a tow but at least its covered.
    VS995 ?
  10. bisco
    52,807
    i keep a donut above decks. that way, if i get a flat, i only need a cup of joe.
    Mendel Leisk and Prodigyplace like this.
  11. Prodigyplace
    12,711
    11,848
    Central Virginia
    Sweet!
  12. beavis87
    23
    El Paso
    Another question is, if the Plug-in has no spare tire does it have a jack and lug nuts wrench?
    VS995 ?
  13. bisco
    52,807
    yes, everything but the tire. and a compressor and goop, if you don't mind killing the tpms.
