fix you a head gasket
Discussion in 'Gen 3 Prius Main Forum' started by georgefrank, Jan 9, 2025.
  1. Mendel Leisk
    42,355
    “Different” entailed running a little richer?
    georgefrank likes this.
  2. Brian1954
    Brian1954 Senior Member
    2,690
    1,076
    South Central PA, USA
    You would be better off if you just buy a rebuilt engine and get rid of the old engine.
    52,863
    If we knew why these engines blow head gaskets, there wouldn’t be any
  4. AVTrainz
    AVTrainz Member
    129
    66
    California, USA
    I don't think OP is going to be satisfied until he figures out the Brazilian recipe to an EGR delete. Too bad here in the US we don't like putting a serving of jailbreak sauce on fine, well done Gen 3s.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,977
    Texas Hill Country
    I would do it if it did not keep the check engine light on AND it did not change the engine operating parameters. However some do block egrs and live with the compromises. Some report unchanged mpg and possibly smoother operation which makes sense if the car is an oil burner accelerating carbon.
    However in this case the Op needs an engine. Rebuilding his is likely to be a disappointment on a major scale. A good engine can have a functional egr and everybody is happy.
    Brian1954, AVTrainz and georgefrank like this.
  6. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Some might say this is off-topic, but I've had vehicles with head gaskets that kept blowing. I should have had the head machined flat, but instead, I applied gasket goo to both sides of the gasket. My mechanic said I was crazy, but it never did blow after that.
  7. bisco
    52,863
    certainy, that is one reason why, but many head gaskets blow before the coolant temp warning comes on.
    it's not always user mistake, but there are many theories
    georgefrank and AVTrainz like this.
  8. AVTrainz
    AVTrainz Member
    129
    66
    California, USA
    I have a feeling you will when it comes time to smog and register the car.
  9. rjparker
    11,119
    6,977
    Texas Hill Country
    blind leading or questioning the blind
  10. Tideland Prius
    16,681
    *Clean up*
