Fixed combination meter, made it worse?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SirDeadSquirrel, Feb 19, 2024.
  1. SirDeadSquirrel
    SirDeadSquirrel New Member
    So I just bought this car with a bad dash, replaced the caps and it worked for a week or so. Hopped in to go to work today and I'm at a bit of a loss. Had check engine light and door light, that's all that showed, like the dial was all the way down (check engin3 light is a permanent fixture now, bad cat and burning way too much oil to replace it).
    Dial didn't do anything, ended up driving an hour with no heat because the blower is no longer working. Hazards work, blinkers do not. No reverse cam, but no problems shifting. This makes zero sense to me and was wondering if anybody had any ideas?
    Before I fixed it it would do the thing where there's no door ajar light, flicking the headlights would fix it then that stopped working, until eventually I finally bit the bullet because I spent an hour plugging and unplugging the battery. This dash issue is different though, plus all the new issues.
  2. SirDeadSquirrel
    Edit: found something, fuse 7 under my dash keeps popping. As soon as I insert it. Car not even on. Any ideas?
  3. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    Without me going to look what is fuse 7 say under the fuse box lid that the fuse 7 is for. Is this in the under hood box or the box above your knee sitting in the car?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    I assume you are putting the fuse in while the car is powered on? Fuse 7 in the underdash fuse box is the 10A Gauges fuse.
    I usually wire a 12V bulb in place of the fuse, a brake light limits current to 2A, while a headlight can be 4-5A. As long as the short is there, the bulb stays bright.
    Move wiring around or unplug related components on the circuit until the light goes dim or out - that's where the trouble area is.
    Time to look in the wiring diagrams.
    Since this is an "ignition on" circuit, you'll want to put a battery charger on while testing.
    Here's the fuse adapters I use. Screenshot_20240220-073807.jpeg Screenshot_20240220-074757.jpeg
  5. SirDeadSquirrel
    It's the one under the dash, I've torn everything down again and have narrowed it down to the cluster, it's shorted somewhere but I have no idea how or where
  6. SirDeadSquirrel
    Did some digging around today, it's definitely the cluster, but I don't have any idea what could have failed. Gonna pull the caps and test again once I get home, but something on that board is definitely shorted. Didn't see any burn or anything. Would have to look to see which one specifically, but the connector that handles the airbag and security lights is fine, but as soon as I plug in the one responsible for the door light and speedo it blows
