Fixed some rattles, maybe this helps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hamocidal, Feb 28, 2016.
  1. hamocidal
    hamocidal New Member
    Rotterdam, The Netherlands
    So today i fixed some rattles that have been bothering me. Im not done yet, so I'll keep updating this thread.
    Front doors
    You will need dynamat and some soft foam pads for this.
    This will improve the sound of the door.
    Dynamat is quite expensive, at your local hardware store you can buy repair tape which is ment for roofing.
    The material is almost the same but the price is a lot lower.
    Start by removing the door panels. Also remove the plastic behind the door panel.
    Next clean the inside of the door, and inside of the door panel.
    Start applying dynamat on the door panel and the inside of the door. Close all holes that the plastic was covering by using the dynamat material. Next use a big foam pad cut it to size and thread all wires that come from the inside throut the foampad so they wont be able to vibrate against the wall.
    Here are some pictures.
    When your done, the speaker will sound a lot better and the door will vibrate a lot less.
    Here is how it will sound
    Next i found a rallte coming from the front panels. When you press on them they make contact with the headlights and you'll here a rattle, clunk.
    I also applied dynamat inside these panels and used some velt on the spot where the headlight makes contact with the panel.
    Here are the results.
    Before
    And after
    sprtent and Rebound like this.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Great work.
    Nature has provided me with a "back-door" solution. Which is that I think my hearing is slowly deteriorating to the point where I can't hear minor rattles anymore, or I mistake them for my own body popping and snapping in rebellion to existence.
    But for those that may have better and/or higher auditory standards?
    Good Work.
  3. Mendel Leisk
    38,721
    Kinda like the truckers on the northern ice roads. One said in an interview: when he heard ice cracking, he'd turn up the radio. :)
  4. hamocidal
    The Electric Me
    Thanks, my dad owns a 2015 Merc E class, which is kind of rattle, squeek and clunk free.
    I want to have the same premium feel, when I'm driving the prius. So when i have time, ill do all the doors, and trunk. The trunk on a prius has very bad sound deadning, it will improve the comfort a lot once that is done aswell.
    Ill keep you guys posted.
    BTW, closing a door with sound deadning also adds to the premium feel.
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Pruis door Dynamat 001.JPG Or this way
