Fixing a Nutty Mess ;)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Apr 6, 2022.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    Working on my HV battery pack, one of the module power stud nuts got rounded a little...then a little more...and more.*** Today, I simply could not remove that nut. NOTHING worked: not WD40, not heat, not vice grips, not a hammer and small pointy things ;)
    I was settling in to dismantle the nut with my dremel tool, when I had one more idea.
    It worked.
    Here's what I had to start with:
    My thought: if I could bend the copper bus bar enough to slip it off of the neighboring power stud, I could twist it...and surely loosen the nut!
    So, I went after it using small punch pins, etc, mostly from the back side. Here's a sequence from the front:
    ...and from the back:
    Grabbed the whole thing with vice grips and twisted. No problem!
    Yes, the plastic is slightly mangled. The copper bus bar too... but nothing a hammer and a little edge touch-up couldn't fix:
    ***Lessons learned:
    * Be careful with those nuts. They are soft metal, easily harmed.
    * Clean before reinstalling, and use the conducting grease every time... Make sure you can remove the nuts next time!
  2. ChapmanF
    18,919
    I would never have guessed 48 inch pounds could do that to one of those nuts.
  3. Mendel Leisk
    42,220
    What socket size are those nuts, 8 mm?
  4. PriusCamper
    PriusCamper Senior Member
    13,364
    5,402
    Pacific Northwest, USA
    Here's the remains of one I did 4 years ago. I think I went out and bought a brand new pair of vice grips and a miniature file kit for it.
  5. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    You can get a brand new bushbar from dealership. Not sure if they sell the nuts too. I prefer to get a new bushbar if it already gets some corrosion rather than cleaning it like mad.
  6. PriusCamper
    13,364
    5,402
    rock tumbler is easiest way to clean bus bars...
  7. MrPete
    507
    194
    Colorado, USA
    Yep.
