Fixing the code P0171 (O2 sensor but idk which one)
Discussion in 'Gen 2 Prius Technical Discussion' started by Sweetlemon, Mar 31, 2025.
  1. Sweetlemon
    Sweetlemon New Member
    davis
    I recently bought a 2009 Prius with 133k miles and after 2 days, this code P0171 started to pop up and when I checked ODM, it seems that the O2 sensor 1 was at 0 volts the entire time. I just wanted to make sure that the correct solution is to buy a upstream O2 sensor (the expensive one) and then either install it myself or pay a auto shop to install it for me. P0171 is the only code that pops out so I'm hopeful that fixing it will be the end of my car troubles.
  2. BiomedO1
    BiomedO1 Senior Member
    4,515
    2,375
    Left Coast
    Are you sure it's the O2 sensor, not an intake leak after the MAF sensor or vacuum leak? P0171 – System Too Lean (Bank 1)
    IMHO: pay a shop to do it - don't buy the part. Their part n their labor = their problem if that code comes back. It's called a warranty.
    If your going to do it yourself; it's located on the exhaust manifold. Most parts store will loan you the correct tool/socket to change it. Match up the stamped part numbers old vs new. Putting in the wrong sensor will trip other codes pointing you in the wrong direction.
    Good Luck......
    #2 BiomedO1, Mar 31, 2025
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Have you checked everything correctly according to this procedure?
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/2054m/cip0171.pdf
  4. Sweetlemon
    davis
    I will check this, but I thought that since the OBD shows that my first O2 sensor isn't working at all due to no voltage showing when driving it means that it can only be a problem with the sensor
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Correction for compliance with the specified parameters consists of the sensor checking the exhaust from the engine and telling it to add more fuel, or vice versa, reduce the fuel, otherwise the mixture is incorrect.
    The sensor can make mistakes when it is faulty.
    But other systems that do not work correctly and transmit their parameters for the primary formation of air and fuel volumes can also make mistakes.
    Then the sensor only informs that everything is wrong, correct it.
    Trouble Area:
    Air induction system
    Injector blockage
    Mass air flow meter
    Engine coolant temperature sensor
    Fuel pressure
    Gas leakage in exhaust system
    Open or short in A/F sensor (bank 1, sensor 1) circuit
    A/F sensor heater (bank 1, sensor 1)
    EFI M relay
    PCV valve and hose
    PCV hose connection
    ECM
  6. ChapmanF
    18,954
    With a reading like that I don't know if I'd rule out wiring.
    Brian1954 likes this.
