Flashing CEL, running rough, multiple codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Old Wolf, Aug 30, 2018.
  1. The Old Wolf
    The Old Wolf Junior Member
    Payson, Utah
    These are the codes that are showing up:
    P0300 2007 TOYOTA PRIUS - Random Cylinder Misfire Condition
    P0301 2007 TOYOTA PRIUS - Cylinder 1 Misfire Detected
    P0302 2007 TOYOTA PRIUS - Cylinder 2 Misfire Detected
    P0420 2007 TOYOTA PRIUS - Catalyst System Efficiency Below Threshold Bank
    C1241 TOYOTA - Low Battery Positive Voltage
    C1256 - Low Pressure Accumulator.
    I know my cat converter has been on the fritz for some time, the CEL was shining away at me. I replaced the main battery with a rebuild about 7 months ago and have had no problems other than the converter code. Drove to work fine yesterday, but when I started up to drive home, the CEL started flashing and the engine was really rough. As I was driving home I noticed that the anti-skid function lit up a couple of times as well (C1241).
    Anyone have any ideas? Possibly a bad ECM? Input appreciated!
    52,820
    how many miles on her?
  3. padroo
    padroo Senior Member
    2,763
    2,253
    Start by having the 12 V battery checked. Prii doesn't like low voltage. How old is your 12 V battery?
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You probably have an oil burner. How many miles? When was the last time you changed the spark plugs?
  5. The Old Wolf
    Payson, Utah
  6. The Old Wolf
    Payson, Utah
    224,000... And never yet. :unsure:
    Mm, probably about two years old if I remember the last time I put one in. But I do remember the symptoms or a little bit different the last two times it needed replacing. Still, probably not a bad idea to check.
    #6 The Old Wolf, Sep 1, 2018
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    you shod not drive when the light is flashing -- telling you that the engine is running bad enough to send unburned fuel to the cat ... unburned fuel will ignite in the cat and destroy it.
  8. The Old Wolf
    Payson, Utah
    So, I replaced my spark plugs, put in a new MAF just because, checked my battery voltage (11.2, looks like it's still alive) and reset my codes. Still misfiring like crazy. Gotta be something else. Unless anyone has any other ideas, I guess I need to take the thing in and I don't relish the prospect - I'm afraid the dealership will want $3,000 to fix the problem and the car's not worth that.
  9. yeldogt
    810
    313
    NE
    Throwing parts is typically not the answer -- my clogged EGR was making the car run rough. Although I did get a code for the valve
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Will also get misfires or rough running from a bad coil pack or fuel injector.
    Label all the coil packs with a marker.
    Move coil pack 1 and 2 to cylinders 3 and 4.
    Do the misfires follow?
    #10 ericbecky, Sep 6, 2018
    mjoo likes this.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Depending on how you tested it, it lookslike the 12V battery is pretty low (11.2), but I can't see it causing misfires. @ericbecky has a good idea for testing the coils.
    Mendel Leisk and ericbecky like this.
  12. Mendel Leisk
    42,323
    11.2 volts is terrible.
    jerrymildred likes this.
  13. The Old Wolf
    Payson, Utah
    OK, will check the coil packs, and I guess it's time for a new battery once I get the misfire issue fixed. I appreciate those who have taken the time to offer help.
    bisco, jerrymildred and Mendel Leisk like this.
  14. The Old Wolf
    Payson, Utah
    Turns out it was bad coil packs, all fixed. Will change out the battery when I have time. Thanks again to all who took the time to give input.
    Raytheeagle and jerrymildred like this.
  15. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Thank you for taking time to follow up.
    Glad the advice was helpful.
