Flat rate manual for engine repairs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rjh427, Apr 30, 2022.
  1. rjh427
    rjh427 Junior Member
    39
    Earth
    Not sure if this is the right forum for this Q but here goes:
    Can anyone provide a time estimate (flat rate manual preferred), for valve guide seal replacement? And would that be with head removal or with head in place using the compressed air trick to keep the valve from falling inside the combustion chamber?
    Oh, I'm looking for what the flat rate manual says for time instead of the labor charge in $'s because different shops charge different hourly rates.
  2. PriusCamper
    PriusCamper Senior Member
    11,089
    4,512
    Pacific Northwest, USA
    Wow... I had to Google that to confirm. Had no idea you could do that... But seems to me on an early Gen3 you'd be better off waiting for the head gasket to fail so you can replace everything at once and do a more thorough& longer lasting job?
    49,429
    maybe techinfo.toyota.com, idk
  4. Elektroingenieur
    2,515
    3,258
    Three Touring
    One edition of Toyota’s Flat Rate Manual allows 15.1 hours to remove and replace the “compression spring and/or retainer and/or oil seal and/or retainer lock” for all cylinders, plus 0.1 hours if the car has air conditioning (operation numbers 141031 and 141031L, ZVW30 series).
    I assume Toyota’s allowance is based on the Repair Manual (more info) procedures, in which the engine assembly is removed from the vehicle and the cylinder head is disassembled.
    Yes, but I find the versions on toyota-tech.eu easier to use.
  5. rjh427
    39
    Earth
    So 15.2 hours and that includes engine R/R. The car does have a/c. Hmm. With 205k miles, it makes me wonder if an engine swap from a low-mileage wreck might be the more cost-effective fix. Gen 4 engines into a Gen 3 sound doable per other posts here, what about Gen 5 engines into a Gen 3? Anyone know of shops in FL, Tampa Bay area, that do that kind of work?
    I called the local Toyota place before creating this post, they eventually put an actual wrench-turner on the phone. Dude said he would have to look it up and get back to me, but he also indicated he would use compressed air, not R/R the head.
    Dude also tried to upsell me on the updated pistons/rings and a few other parts IIRC, then he tried to put some fear into me about low oil & how low oil pressure can damage rod bearings, which would definitely make the swap more cost effective I think.
  6. Mendel Leisk
    38,700
    Hows the oil consumption?
    And no offense, but can you be a bit more specific about your location?
  7. rjh427
    39
    Earth
    I haven't driven it a whole lot, so that's difficult to quantify. Over the last year I've put about 3k miles on it, added a tad over 2 quarts.
    And no offense but Tampa Bay FL area, Pinellas and/or Hillsborough counties is as specific as I'm willing to get.
    bisco and Mendel Leisk like this.
  8. Mendel Leisk
    38,700
    That's getting up there, for sure.
    Thanks. Putting something to that effect (in place of "earth") will help responders.
    jerrymildred likes this.
  9. rjh427
    39
    Earth
    I said where, earlier, as you can see and verify. I thought you were after my street address or something.
  10. Mendel Leisk
    38,700
    Ah, ok. But sub'ing that info for "earth" in your avatar, people can tell your "approximate" location at a glance, without needing to search through the thread.
    Hey, I'm from earth too, lol.
    jerrymildred and bisco like this.
  11. bisco
    49,429
    don't give mendel any ideas , he's been scouring north america for blown engines :cautious: :p
  12. bisco
    49,429
    there's no such thing as gen 5. yet.
    try todd at tampa hybrids. @jerrymildred works there. he might be able to advise
  13. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    You could try calling Todd at Home - Tampa Hybrids Inc.. As @bisco said, there's no such thing as a Gen 5 Prius. I doubt that Todd would put in a Gen 4 engine since that's considerably more work. But we do replace the occasional engine. You'd have to ask him about cost and scheduling.
    (I had no idea Earth was so close to Tampa!! :LOL: As @Mendel Leisk suggests, your actual location, even if it's just state & county, would help people know what to advise without jumping into a research project.)
