Flexiable Bladder or whatever its called
Discussion in 'Gen 2 Prius Technical Discussion' started by 05hybrid, Mar 10, 2011.
  1. 05hybrid
    05hybrid New Member
    29
    Corpus Christi
    Ok, so im at half a tank and when i tried filling it up, the damn thing kept on clicking....Does this mean something? Is my flexiable bladder messing up :confused:
    Whenever i turned off my car, i sat in it for about 3 mins....I read that if you do this, i shouldnt have any problems filling up
    help plz
    thanx
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Burn some more gas, fill at 1, 2 pips, your call.
    Fill till it clicks, that should be about 8 gal so.
    Position of nozzle is also important. When I fill I wait till first click, then lift nozzle pump some more, usually about 1 gal more.
    Just don't ovefill.
    That trashes the cabon vapor recovery cannister.
    Thats bad Egon.
    At least that's how a '08 takes gas.
    8 gal = 400 miles...SWEET![​IMG]
  3. Patrick Wong
    18,199
    6,464
    I suggest that you keep track of your fuel consumption by using the MFD mpg and trip odometer readouts. If you know that the car consumed 6 gallons, then pump 6 gallons before you are done, and don't worry about the fact that the pump is clicking off.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Try a different pump. Some nozzles are more sensitive than others.
  5. 05hybrid
    05hybrid New Member
    29
    Corpus Christi
    Ok thanks for the advice guys...ill just wait until I'm down 2 pips or so...
    Everytime it goes down to 4 pips...it always takes like about 4-6 gallons
  6. bisco
    48,995
    you're on the right track.
  7. Rest
    Rest Active Member
    1,210
    53
    CA
    I this same type of issue with another vehicle trying to fill the tank, where the nozzle kept clicking the pump off. So it's not confined to just the U.S. Prius.
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Don't waste your time sitting in the car for 3min. It's not going to help anything. :)
  9. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    I find on some super-sensitive gas pumps you have to pull the gas lever just slightly to get a small stream to fill it up.
  10. sstk100
    sstk100 Junior Member
    Ne
    Fill the tank at the slowest setting on the pump....fill it slowly.
    You can also remove the pump handle (at about mid fill) ...from your car for 15 seconds or so, .....so that air can be released from the tank.....Then continue to finished filling the tank....slowly.
    When it's colder (about freezing and below), the tank bladder stiffens up, and won't expand fully....so it's harder to get filled.
    Toyota has made some changes in the tank to fix some of the problems in the 04 to 09 tanks. I had to change out a tank in an 08 and found out the earlier tanks were different.
  11. richard schumacher
    7,663
    1,038
    United States
    It's a bad idea to sit in the car after starting the pump. Leaving and returning to the pump can leave you with a potentially dangerous static charge:
    [ame=http://www.youtube.com/watch?v=b3x-8tj49ac]YouTube - Gas Pump Fire[/ame]
    The safest thing is to keep your hand on the pump handle the entire time.
  12. 05hybrid
    05hybrid New Member
    29
    Corpus Christi
    Lol...I didn't do that...I sat in the car for 3 mins to let it the fumes breath out of the tank...then I got out of my car, got the gas pump and started pumping the gas
  13. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    OP - I do not know how long you have had the car or your location so I just thought that I would mention that this is a far bigger issue in the cold. Once the weather warms up the tank is far more accommodating so just another reason to look forward to summer.
  14. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    This is why they don't let people in NJ pump their own gas. :cool:
  15. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Here they let us pump the gas, but they remove the clip that lets you hold the pump open... you have to hold it throughout the transfer.
    Maybe there's another reason NJ doesn't let you pump gas... big political donations from the pump jockey unions?
  16. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    haha!! Did you see her try and blow it out with her mouth! That made me laugh out loud!
  17. robert shrum
    robert shrum New Member
    linolnton nc
    i had the same problem i just bought a 2009 used prius i started to fill the tank and the pump shut off i had to put gas in slowly. after i got 8 gal in i pulled the handle out and gas shot out all over me and the car and it keep bubbling in the fill tube. and the temp. was about 65 degrees out side.
