Flicker
Discussion in 'Gen 2 Prius Technical Discussion' started by Kelli Ann, Sep 27, 2016.
  1. Kelli Ann
    Kelli Ann Junior Member
    33
    St. Petersburg, FL
    Hello,
    I searched this site and didn't find any help.
    I've had my 2008 since the end of March 2016, now the end of Sept 2016 (just over 81K miles). I have had only 2 instances of a full flicker in the last 90 days. The instances happened at night, so not sure if it has happened in the daytime or I just didn't notice. Headlights, dashboard and system screen all just flickered. The car didn't seem to shut off or stop as I was in forward motion.
    Could this be just a system reset or is the the beginning of the 12V aging, getting ready for replacement?
    Thank you for any thoughs or suggestions.
    49,375
    hard to say, could be a loose connection. always worth testing the 12v, but never heard of flickering head and dash lights before.
    valde3 likes this.
  3. mailtrain13
    mailtrain13 New Member
    Orlando,Florida
    Hey. Did you find any solution to this? I am facing similar issues with my 08 Prius
  4. Kelli Ann
    33
    St. Petersburg, FL
    Hello, Actually no, not really. I have replaced the 12 volt once - the end of 2016 as I left the car on auxiliary on day and killed it. So maybe it was a loose wire. So check your connections on the 12. I love the car. The paint is started to really show some wear and tear and i may need some tires this year. Enjoy!!
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    If the dashboard module is flickering or just out that is a very common issue for failure. The dash led module is called the Combo meter.
    It goes from intermittently going to black and progress to you cant shut the car off with out disconnecting the 12 volt battery which is very inconvenient.
    use the search forums up top and search:
    combo meter
  6. bisco
    49,375
    check the negative to ground connection
