Float hybrid
Discussion in 'Gen 3 Prius Technical Discussion' started by Ben Schneider, Mar 12, 2022.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    Is there a way to float the hybrid battery while left with no one to start it for a month or two.
    i have a 12v solar charger.
  2. ChapmanF
    18,620
    You might be able to cobble something together using your solar charger, an inverter, and one of the "grid charger" products available for the traction battery, assuming the capacities work out. Maybe with some kind of a timing or control scheme involved.
    Ben Schneider likes this.
    52,436
    the hybrid battery will be fine, float the 12 volt
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Aha... I took the word "float" literally. I see float charging the traction battery.
    I agree with @bisco. Don't need to float charge the traction battery, but yes the 12v battery will need it.
  5. PriusCamper
    PriusCamper Senior Member
    13,137
    5,321
    Pacific Northwest, USA
    Yes... Though a truck driver on here once went more than year without using his old Prius and it started up just fine with no issue.
    Basically, what you need is 110v power supply switch on a timer or wifi so you can turn it on remotely...
    Then you need a high voltage super low amp charger... Hybrid Automotive and Maxx Volts make them. Or you can build your for $100ish: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
  6. Tombukt2
    Tombukt2 Senior Member
    13,517
    2,433
    Durham NC
    RAJ from Venice hybrid makes my 2.4Ah 335V. Gen 2\3 charger .but it could not be left unattended.
  7. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I would not worry about it. I would Park it with it the High 3/4 full according to the gauge on the dash. Like others have said I would charge the 12 V with a trickle charger. Or the solar charger that you have.
