Flooded 12v battery area, wet insulation/carpets
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hyp3rmil3r, Jan 12, 2020.
  1. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    Went to look under at the spare tire area while cleaning today. I found that the 12v battery is sitting in a pool, and a lot of the insulation and carpet around that area is pretty wet. Not sure if anyone has any idea one what could cause this?
    iPhone ?
    49,488
    it's usually cracks in the rain gutter welds. under the black trim. most people use a silicone sealant.
    Travis Decker and hyp3rmil3r like this.
  3. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    @bisco I’ll take a look next time i get some free time, thank you for the suggestion!!
    iPhone ?
    49,488
    less often, it's the hatch rubber seal or the hinge points
    dig4dirt and hyp3rmil3r like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    While that's the cause, most people just drill a hole at the low points in the various areas;).
    Fixing the cracks can be fiddly, so just be aware of another tact(y).
    hyp3rmil3r, edthefox5 and dig4dirt like this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Very common for 12 volt to be swimming in its hole. Take the battery out there's a rubber plug in the bottom of the well. Don't remove the plug just drill a hole through it to vent the water. Do the same to the rubber plug under the spare tire.
    If you remove the plug and the car lives outside you may get a mouse infestation which is also very very common. Mice love the taste of the G2 wiring.
    Raytheeagle likes this.
  7. hyp3rmil3r
    hyp3rmil3r Member
    120
    93
    Northeast
    The drill suggestion is fantastic, thank you guys so much. I’ll try to find the cracked plastic piece as well!
    iPhone ?
