Flooded prius not finding key.
Discussion in 'Newbie Forum' started by Waterprius, Jul 10, 2019.
  1. Waterprius
    Waterprius New Member
    Olmsted Falls, OH
    I have a 2010 prius that was in a flood up to about the middle of the door pillers. It jas completly dried and most of the electical componants have been replaced (computers, transmitters and ecu's). The car will recognize when the start button is pressed, says somthing like "key not found". I have had a locksmith come to the car and try to reset the key system so a new key can be programmed. When he does this it gets through 16 min of the reset program and says its done. After it says it is done reseting, it says there are 2 keys in the system memory and will not reset to 0 keys in memory? Any ideas for fixing this problem?
  2. PriusCamper
    PriusCamper Senior Member
    13,479
    5,446
    Pacific Northwest, USA
    You need a locksmith with Toyota Techstream's security feature (monthly fee) to wipe and reseed your existing FOBS in the system. YEars ago on here their was a service in Europe that for $30 would do the mathematical calculations of your Vin# to allow you to use Techstream to wipe and reseed without the monthly fee... I could dig that info up possibly if you can't find it?
    It's also possible, but unlikely that the immobilizer unit has water damage and needs to be replaced.
    Data Daedalus likes this.
  3. Waterprius
    Olmsted Falls, OH
    Thank you. The immobilizer unit i believe was replaced. I have the toyota manual and electrical diagrams book for the prius. Im not sure what the locksmith used. I will find out and look for the european service info on here. Do you happen to know what posting it might be under?
    52,923
    welcome!
    have you checked the fob batteries and 12 volt?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
    halfway up the door pillars? Was this a totalled car that you're personally trying to recover or is insurance company trying?
    Skibob and PriusCamper like this.
  6. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    Hello. I can clone your immo module to new one.
  7. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    What is your plan to save the car?
  8. Travis Solomon
    Travis Solomon New Member
    I also think soo that you need to take it to a workshop that fix this problem.
