Floor covering options
Discussion in 'Prime Accessories and Modifications' started by KrPtNk, Jun 16, 2017.
  1. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    IMG_1951.JPG i was recently at a dealership looking at a Prime. The car's floor had no mats and the bagged optional equipment packages were in the hatch area.
    What covers the floor in the car as it is shipped from Japan?
    It seems odd for the dealer to order a car with all weather floor mats and also carpet coverings that would be completely hidden by them.
    Why would I want to pay $299.00 for carpets that would be covered by the all weather mats? It would be just more weight to haul around.
  2. MartyPrime
    MartyPrime Junior Member
    50
    86
    Los Angeles
    Yeah, definitely do one or the other. Often dealers add on options to increase the price. The regular mats it comes with are fine. They will get dirtier and harder to clean then the all weather rubber mats. So i would go for one or the other, but definitely don't buy both.
  3. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I've had both type of mats for all my Priuses - I put the carpeted mats in for late spring/summer/early fall, then put the all-weather mats in for snow/slush season.
    That reminds me - i have to buy all-weather mats for my wife's new Prime! :D
  4. GLouderback
    GLouderback Member
    Lower Merion PA
    Whatever you do don't put the all weather mats over the summer mats. It's one or the other. Personally, I like the all weather mats year round. They are made just for the Prime and fit like Weather Techs. In fact, they may be made by WeatherTech. I was told they are made in the USA.
  5. Hybrid Battery 911
    Hybrid Battery 911 New Member
    Canton GA
    Agree with the other posts, one or the other considering the high dealer cost.....I prefer the all weather mats for easier clean-up and longevity.
    Prodigyplace likes this.
  6. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    My wife, before she passed, got me the hard, thin vinyl mats which I used over carpeted factory mats for 5 years in my 2012 PIP, and am now using in the same way on my Prime Advanced. No, there is no interference whatsoever with pedals, although rear mats don't quite fit. The advantage is: weatherproofed floor, and noticeably quieter car.
  7. Prodigyplace
    12,709
    11,847
    Central Virginia
    If you buy the Toyota mats, they are likely cheaper from Amazon. That is where my son & I both got the Toyota all weather mats for our Prius vehicles.
  8. Prodigyplace
    12,709
    11,847
    Central Virginia
    My Prius came with the carpeted mats because my deler orders them all that way. I bought the Toyota all-weather mats from Amazon and swapped them out. I agree you cannot use both at the same time.
  9. Prodigyplace
    12,709
    11,847
    Central Virginia
    You cannot use both at the same time. Toyota has warning labels on the mats warning against that and both cannot fit in the hold-downs for the drivers side floor mat.
  10. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    There are/were no hold downs on either Prius for the mats. Toyota Corporate does not want a repeat of the unintended acceleration fiasco under which it was sued; I understand this. I'm a private citizen who has examined and tested my particular situation and found the installation to be satisfactory. It must be noted that there are floor mats and there are floor mats; the thin hard vinyl mats on top of the carpeted mats grip them with hundreds of nail like projections and lie completely flat, and are well away from any pedals. I'm not encouraging anyone to do what I've done; I'm merely stating the facts in my case with my car. On my Honda Insight and my Acura Type R, I had used Dynamat installed/glued under the mats, and inside of the doors; this proved fairly effective in quieting those cars. The installation, though, was pretty expensive.
  11. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Floors are carpeted from the factory; no mats. Accessories are usually added at the port of entry or by the dealer.
    HPrimeAdvanced and KrPtNk like this.
  12. KrPtNk
    323
    283
    Pacific Northwest
    It made no sense to me to use both simultaneously and they aren't cheap.
    I didn't know that. I assumed that the car would be shipped with some kind of lightweight, inexpensive mats.
    I think that the dealer was just giving the buyer summer and winter choices.
    I live in the country in Oregon. All weather mats are the only option.
    Thanks for all the comments.
    HPrimeAdvanced likes this.
  13. alexcue
    alexcue Active Member
    346
    311
    So Cal
    The Toyota Owners App shows both of my Toyota vehicles, in there it shows what came from the factory and what was added at the port. It even has detailed records of my 2002 Tundra.
    Mine shows the edge guard and carpeted floor mats/ cargo mat were added at the port.
  14. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    I don't care how much the mats cost, I always buy both, carpet and rubber. After you spend 30K on a new Prius, who cares what the mats cost?! :)
    The Toyota carpet mats seem to be much thinner and lesser quality than in the past. But Toyota made sure they won't slide around. The bottom is some type of Velcro or something, and they stay put! I do a lot of hiking and going to nature trails, so I also bought the rubber mats and threw them right on top of the thin carpet mats. They don't slide around either, and fit like a glove. Well worth the money. Last thing I want to be doing is keep cleaning/vacuuming those carpet mats. Rubber is easy, just wipe with a wet rag or hose them off, and throw 'em back in.
    #14 CoastRider, Jun 17, 2017
    tanner9868 and HPrimeAdvanced like this.
  15. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    I know this is an old thread, but that sounds like a great mod. Can you post a link to these plastic mats, or brand name and picture so I could find some.
  16. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    The car is shipped from Japan with no floor mat, I think. The dealer option of carpet mat or all weather mat is almost always included into the car sold in the US. You can try to negotiate the price of the floor mat off from MSRP telling them you don't want that option. You can always buy them cheaper after you purchase the car. Often dealer will just give the mat to you and take of the price. You can't use both carpet mat and all weather mat at the same time, but people do like to switches between them for all weather in winter and carpet in summer. That said in my local, all weather mat is must have for the salt and snow in winter and dirt and mud in summer time.
    Edit: Whoops! I responded to an old thread resurrected recently. OP probably already have bought the car. lol
  17. Tideland Prius
    16,665
    Yup he already has one and is thinking of upgrading to the 2020 or 2021 Prime! haha
    The Canadian spec carpet mats and all-weather mats are thin enough that (except for the driver's side), I put the carpet mats underneath the all-weather mats. Part of it is psychological (the carpet mats can help reduce noise... a little bit) but it's also to further protect the original carpeting is I always assume is thin as heck and it's cheaper to replace a piece of removable carpet than the floor liner itself.
  18. Salamander_King
    11,024
    8,977
    New England
    Are OEM floor mat different from USA and CANADA? I did not like the OEM all weather floor mat for Gen3, and ended up buying WeatherTech. The all weather mat that came with PRIME was heavier than Gen3 and covered bigger area with molded shape much like WeatherTech one. So I kept it. At some point when I have to buy a new one to replace it, I probably buy another OEM mat. Only thing is that they don't sell just driver's side. Most likely the only one needing replacement is the driver's side.:(
  19. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    But noticeably less sturdy than the Weathertech. I'm using the factory all weather mats for now, but if they wear out I'll replace with Weathertech. So far, the factory mats aren't wearing very well.
    Dael likes this.
  20. Salamander_King
    11,024
    8,977
    New England
    Yeah, but you don't get the "GREEN" leaf symbol and PRIME logo on Weathertech or Husky mat. ;) I haven't priced each option, but If I can find driver's side OEM mat only on ebay cheap, I will go for it, otherwise, the set price for Weathertech might be cheaper?
    jb in NE likes this.
