Floor Jack Recomendation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Dec 28, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Can anyone recommend a decent make of floor jack for the backyard mechanic type?
    Thanks All
  2. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You do need one that starts off very low. Mine won't fit under the car unless I drive it onto 2X material.
  4. Mendel Leisk
    42,345
    Don't know of specific good brands. I would suggest to get one rated 3 tons; they tend to have more lift range and are more solidly built. A hardened rubber cradle is nice, or you can retrofit one. Regular steel cup cradles can be hard on the lift points. You can also cobble shims, plywood or 2x4 blocking.
    I got my "genueen" Samona jack for $69 on Boxing Day, maybe 10 years back. It's just regular looking, not low-profile, but just clears front bumper and front lift point, no problems.
    Got it at Summit Tools: was supposed to pick it up from their loading bay, but it was down a terrifically steep decline, and while bare, it was cold and snowing hard. Their warehouse guy heroically dragged it up the slope for me, lol. (y)
    #4 Mendel Leisk, Dec 28, 2016
  5. PosauneGuy
    PosauneGuy Member
    124
    91
    California, here I come...
    2025 Prius
    I picked one up at Costco (Arcan 3-ton) for $100. Works great!
  6. Taxi/Limo
    526
    107
    Thanks for the suggestions I wonder what kinds of floor jacks typically have low profiles ?
    Nexus 6 ?
  7. David Beale
    5,963
    1,990
    Edmonton Alberta
    The ones made for "racing" and sports cars are low profile. Hence some here have the aluminum ones, which are made to look like NASCAR jacks.
  8. milkman44
    milkman44 Active Member
    591
    386
    Ky
  9. Mendel Leisk
    42,345
    My 3 ton is very regular profile, works fine. The front/central jack point is some distance back, and clearance is not great, but not bad. I wouldn't get too hung up on the low profile requirement.
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    That is unless it has been modded lower.
    A picture of @Taxi/Limo 's Prius would help the discussion;). If stock, the 3 ton jack from harbor freight works well and I have been using it on our stock 2010 Prius II for over 7 years with no issues. The front lift point is deep in there, and jacking up at the start is slow but it does the job well.
  11. Mendel Leisk
    42,345
    Yeah, and if you've lowered, just rolling the front wheels onto something like 2x10's should remedy.
  12. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Harbor Freight has a very good selection of floor jacks. I suggest a jack with 23" of lift (that seems to be the maximum). I bought their Daytona model, but they have a few for about $125 USD which are heavy duty, 23" and low profile. And pick up 2 or 4 of their jack stands while you're there. They also sell red vinyl covers for the jack stands to prevent scuffing the car
  13. Mendel Leisk
    42,345
    Yeah you can never have enough jackstands. Wheel chocks too: 4 heavy rubber ones will do it.
