Floor Jack/Tire Rotation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rae, Mar 3, 2010.
  1. Rae
    Rae New Member
    MA
    There have been some previous discussions about the use of a floor jack for pre-GEN III models. Having recently done the recommended 5000 mile rotation on my 2010 iv, I found the following method works well.
    Locate the notched rail where the Toyota jack is to be placed behind the front wheel. Place a short piece of 2X4 on and perpendicular to the rail (I used an 8" piece) behind the notched area, flush with the outside edge of the rocker panel. Center the jack cup directly under the rail (NOT THE ROCKER PANEL) on the 2X4.
    Using this method I was easily able to lift one side of the vehacle enough to remove front and rear wheels.
    During the process I discovered that the factory had a problem with their torque wrench during installation of the right side front and rear wheels (July 2009 delivery). One lug nut on each wheel was so tight I had to use a 2' breaker bar to get it off as the impact wrench would not budge it, nor could I get it loose using a standard star wrench and standing on it (I weigh 220#).
  2. mmichaell
    mmichaell Member
    241
    chicago
    I remember back in the day that over-torqued lug nuts supposedly could cause warped rotors, thats why I always rotated my tires myself. I guess now I have to worry about the factory doing it incorrectly - I should just rip off all the hubcaps and check this.
  3. Tom183
    Tom183 New Member
    652
    65
    Maine
    The Gen III has a front lift point and a rear lift point for use with floor jacks - see page 423 of the manual. (and don't forget to set the parking brake and chock the tires)
  4. Tom183
    Tom183 New Member
    652
    65
    Maine
    And don't ask me why they put that in-between other sections which have nothing to do with changing the tires - or why the tire-changing section is completely separate...
  5. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    That's great except that you normally rotate tires front-to-rear, not side-to-side.
    Valiant V likes this.
  6. Joe166
    Joe166 New Member
    720
    97
    South Florida
    And that is great too, but it can be useful for removing the rear tires to put on the mud flaps, or if one of your tires goes flat, so it certainly has validity.
  7. vegasjetskier
    269
    29
    Absolutely.
  8. Former Member 68813
    3,524
    983
    US
    i must be tired, because i don't get it. can someone please explain how to jack the whole side with a floor jack?
    i tried them and it's a big hassle to use those points while trying to do wheel rotation (i had to raise/lower the car 5 times). to be honest, it's simpler to do just the scissor jack as one needs to lift just a corner and not half of car like with the floor jack.
    as a matter of fact i had to use the scissor jack for left rear wheel, as the rear floor jack location is on the right side and does nothing for the left wheel.
    so far I'm not convinced the money for the floor jack was not wasted.
    thanks!
  9. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    This is pretty much the same way I rotate mine. Easy peasy and fast and easy.
  10. Mendel Leisk
    41,824
    My method, third gen, using the procribed front and rear central jacking point:
    1. Chock rear tires.
    2. Raise front and settle onto safety stands*
    3. Raise rear and settle onto safety stands*
    * Safety stands not placed at the scissor jack bearing points, find them too flimsy/unstable. Instead use these points:
    ETC(SS) and Salamander_King like this.
  11. Former Member 68813
    3,524
    983
    US
    which one?
  12. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    Sorry, I meant the OP. Floor jack, 2x4, jack up one side at a time.
  13. Former Member 68813
    3,524
    983
    US
    thanks, could you please shot a picture next time you do it?
  14. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    certainly
  15. working1
    working1 Active Member
    121
    112
    I use two (2) floor jacks with notched plastic pucks to jack one side to rotate tires. The round pucks can be found on eBay. I'm not sure how a single floor jack would work or how stable it would be trying to lift one side.
  16. Mendel Leisk
    41,824
    Meh, play by the rules: raise front, safety stands, raise the rear, 'nother couple of safety stands. Now you've got all four tires an inch or two clear: go nuts.
  17. Former Member 68813
    3,524
    983
    US
    can you raise both rear wheels with the factory jacking point in the rear in your car? i only succeeded with the right rear.
  18. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    yep/
  19. Mendel Leisk
    41,824
    @friendly_jacek yes, no problem. Maybe your jack doesn't have enough travel? The jacking point is kinda high, and a little over to right side. I use a 3 ton jack with theoretical 21" saddle height when raised. I put a square of 2x4 plus hockey puck in cradle for a bit more reach. Even not at its limit, the tires are an easy 4"~5" off the slab.
    For the front point I use this:
    #19 Mendel Leisk, Mar 31, 2016
  20. Patrick Wong
    18,210
    6,511
    1. Get a length of 2 x 4 lumber, around 2 feet in length. The point of using this wood is to distribute the lifting force along a longer area since you are going to lift up the entire side of the car, 1,600 lb of weight or so, with just the one floor jack.
    2. Place that lumber in the lift saddle of the floor jack.
    3. Place the jack so that the lumber is contacting the rail of the car that the notches are cut in for the scissors jack, but place the jack below the front door, near the center of the vehicle, but towards the front of the car since the weight distribution is biased towards the front, approx. 60% front/40% rear.
    4. Raise up the jack and both the front and rear tires will lift off the ground assuming you placed the jack correctly.
    #20 Patrick Wong, Apr 1, 2016
