Florida Heat + HV Battery = ???
Discussion in 'Newbie Forum' started by Chris Papaya, Dec 2, 2017.
  1. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    I live in South Florida. It gets really hot in the summertime. You can cook eggs on the driveway.
    • How is this going to affect the HV battery over time?
    • Is it more likely the battery will die sooner rather than later?
    • Maybe there is some preventative maintenance I could do to keep it in good shape?
    • Should the car always be in shade. (Because that is kind of a troublesome requirement)
    I understand the battery has to be cooled through the vents, but what about when the car is hot. I want to buy a white color Prius so some heat can be reflected.
    I have a carport, but it might not always be available. So any information would be greatly appreciated on this topic. Thanks.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    I would get the windows tinted with the ceramic tint that really cuts down on interior heart, it isn't cheap but worth it!
    Also if you buy used, I'd probably clean the battery fan to make sure its clean and in tip top shape.
  3. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Oh yeah definitely, I already planned on purchasing good dark window tint for it. However I didn't know there was a 'ceramic' type of window tint. I thought they were all the same. Thanks.
    52,860
    try to park in the shade. warm battery at arrival and cooking all day definitely reduces life span. a/c while driving eliminates that part of the equation.
    RCO and jerrymildred like this.
  5. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Yeah that is what I was afraid of. :unsure: Here in South Florida in June,July, August, it is inescapable. Just the seatbelt clip will give you 2nd-degree burns if your not careful. Well that is bummer. :(
  6. bisco
    52,860
    the tint, and window shades will help a lot, it's hard to define the problem, but we have plenty of florida members.
    anecdotally, we do see more failures across the south than the north i believe.
    another important thing is to keep the battery cooling fan and grille clean and clear.
  7. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    I would try to not drive super aggressively near the end of a drive, that can heat up the battery and have no way to cool when the car is turned off.
    Yes what Bisco said, being in south FL you want to keep down the humidity as well, over time it can corroded the battery. We have a member with a 2004 that lived in Arizona its whole life and never had one problem till he sold the car about a year ago. They don't have a salty humid are though. Just keep that in mind.
    But also Prii batteries are though as hell and can take a beating!
  8. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    I've got a 2004 Prius that was built in 2003, it still has its original battery that still has amazingly amout of capacity and performance left, even I'm shocked!
  9. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    That battery is almost 15 years old!
    RCO and Andyprius1 like this.
  10. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Holy crap. Thats crazy. Then I must say that is a very resilient battery. Do you livr in south florida?
    Just to let you know i am not an aggressive driver. I drive smooth and slow and build up to speed. Thus one of the reasons my driving style fits the prius.
  11. Prodigyplace
    12,715
    11,848
    Central Virginia
    Raytheeagle likes this.
  12. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    I live in Nashville Tennessee, so pretty north, but it still gets up past 100 degrees in the summer.
    Also, too slow or smooth can actually tax the battery as well, because the car will cycle the battery more and use all electric power, just to keep that in mind when driving in extreme heat.
    The key to efficient Prius driving is not draining the battery, but making the gas engine run efficiently, after all it is a gas powered car. Just food for thought. What year Prius are you getting?
  13. Prodigyplace
    12,715
    11,848
    Central Virginia
    Their profile says 2004 Prius II
  14. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I have used the Prolong setup and it works well:)!
    Have the charger and Intelligent Discharger for our 2010 Prius II with 168 k miles and going strong ;). It’s a great way to maintain your hv pack.
    As for heat avoidance in a hot area, crack your windows to allow the heat inside out;). You can also put the cover over the cargo area to avoid direct sun light.
    Hope that helps (y).
    Aaron Vitolins and Prodigyplace like this.
  15. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Opps! It's been said the 2004 are bullet proof, ya know!
    Prodigyplace likes this.
  16. Prodigyplace
    12,715
    11,848
    Central Virginia
    Perhaps, but not heat proof. :D
    RCO, Raytheeagle and Aaron Vitolins like this.
  17. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    A tint doesn't have to be DARK to be good.
    Some block mostly the Infared (heat) waves and less of the visible light.
    I think that is what the "ceramic" reference is about.
    The real key is to not leave it sit out in the direct sunlight all day long.
    But yes, a cold battery will last longer than a hot one, in general.
    That one fact, however, will NOT convince me to move back where I have to shovel snow 4 months a year !!! ;)
  18. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Ohhhh. Well whatever the needs are to get better performance I will change my driving habits to get the most out of the Prius.
    I dont own a prius. I currently drive a 2001 corolla but i want something better. Something i can use as my daily driver car to/from work but also something i can go for 3 weeks cross country and carcamp in.
  19. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Thats a good idea too. I will buy rai. Shields so i can keep the windows cracked open a bit.
  20. Sam Spade
    2,036
    1,024
    2017 Prius c
    Not practical here if the vehicle sits out.
    It rains most every day in the summer scattered around the state.
    And cracked windows let IN critters, which also abound.
    And there is nothing you can do externally to reverse the chemical changes that are accelerated by excessive heat.
    RCO likes this.
