Florida Heat + HV Battery = ???
Discussion in 'Newbie Forum' started by Chris Papaya, Dec 2, 2017.
  1. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Well the rain shield will prevent water from coming in. Not many bugs i expect to get in. Ima crack it like .5 or .75 inches
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I installed some vent shades on our 2010 to allow for venting and avoid water intrusion or others knowing the windows were open ;):
    1D0175DF-A647-4D30-8805-4B0C5B792375.jpeg 9C0ADA03-17B9-4DB6-A87B-FE26D2E51FC1.jpeg
    They work well(y).
  3. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    You may know this already, if you need AC so does the car, so always use it and your HV pack will Thankyou!
    pilotgrrl, RCO, jerrymildred and 2 others like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    What I do is try to park in the shade whenever possible. Barring that, I use the Sunshade heat shield on my windshield. It's available on this site, but several people have experienced delivery problems. The only other place I've found it is from the maker for a few dollars more than here.
    I also use the vent shields so I can leave the windows cracked open a little bit. Those combinations drop the inside temperature quite a bit. And I always keep the cargo area cover in place.
    All that said, it gets considerably hotter in the midwest than it does here in Florida. I grew up in NW Iowa and it was over 100 lots of the time. It's just that here it's hot for a LOT more days.
    So don't let the heat deter you. There are lots of Prii in the south that have plenty of miles and years on them.
    #25 jerrymildred, Dec 2, 2017
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Beautiful car, Ray. :cool:
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That probably should work.
    When you find it FULL of love bugs in the spring and fall, let us know how you get them out !! :D
    (Mostly joking.......mostly.)
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    'Heat' is not so much the problem as "Heat inside the Battery". Folks who live in the mountains build up heat charging and discharging very rapidly on hills. There are no hills in Florida, let alone south Florida. This will work in your favor.
    The A/C cools the big battery, run A/C to treat the battery good. Avoid huge charge/discharge cycles when it is hot inside the car. In FL that should be easy.
    Good tint to the legal limit in FL
    Front Side Windows Must allow more than 28% of light in.
    Back Side Windows Must allow more than 15% of light in.
    Rear Window Must allow more than 15% of light in.
    The window shades while parked will help. (PriusChat has then for back and sides as well)
    Sunshade HeatShield for 2016-2017 Toyota Prius - Front - PriusChat Shop
    RCO likes this.
  9. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Of course. I live in Florida. Im almost always using the AC. My main concern is the summer heat in mid july as the car bakes under the sun and the interior is 140F+
  10. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    What is the cargo area cover? Is tha like a tarp or something you throw over car?
    Hmmm. Well that helps ease my concerns. Thanks.
  11. bisco
    52,803
    there's a tonneau cover that rolls out in side the hatch to hide anything in there. it also helps keep the sun off the battery area a bit.
    it should come with the car, unless they lose it.
    jerrymildred, RCO and Raytheeagle like this.
  12. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Alright well that settles it for me then. My plan:
    White color car
    50% tint windshield
    25% surrounding windows
    Sunshade on windhsield while parked
    Rain shields/windows cracked open
    Cargo cover
    AC while driving (typical for me)
    No intense charge/discharge cycles
  13. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    Ohhhhhhh that thing. Ok yeah ive seen that.
  14. bisco
    52,803
    park in shade when possible, be prepared for bird doo-doo.
    jerrymildred likes this.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    That happens to all of us, too. Just click Report on all but the one you want to keep, and the moderators will whisk the others away.
    (I would be sure I understood Florida's tint law on tinting a windshield)
    RCO, jerrymildred and Prodigyplace like this.
  16. Sam Spade
    2,036
    1,024
    2017 Prius c
    I used to think that too......until I lived here a while. There ARE hills.
    Of course, a lot of them are overpasses on the Interstates. :ROFLMAO:
  17. jerrymildred
    11,517
    14,167
    Tampa, FL
    Too true!
    According to peakbgger.com, the highest point it FL is Britton Hill, 345' above sea level. There are several "Mounts" such as Sugarloaf Mountain, but those terms are exaggerated. AFAIK, no one has ever experienced altitude sickness in Florida. :LOL:
    RCO likes this.
  18. Chris Papaya
    Chris Papaya Member
    78
    34
    Fort Lauderdale
    This is about the highest elevation I will have to be dealing with. lol.
    https://goo.gl/maps/S1ZhS5qkxh82
  19. Andyprius1
    2,327
    859
    Cool CA
    I remember all the little causeways between Miami and Miami Beach, aren’t those hills? or elongated speed bumps.
  20. Andyprius1
    2,327
    859
    Cool CA
    Let’s face it, the whole portion of Fl is/ was man made. Nature knew what she was doing and did it well.
    The US Army Corps of Engineers contributed greatly to the destruction and changes to the Okeefenokee swampland. As a result, many creatures have disappeared or been greatly lessened thru sheer ignorance. The only Humans that greatly understood the waterways, and thier benifits. And respected what was there and thiers, was the American Indian tribes. They managed the swampland nicely by doing nothing. This is a very much missed point that the paleface never got. The Indians saved our country so we could come along and destroy it! Aren’t you proud of your ancestors? It’s OK you can condemn them now, they are dead.
    RCO likes this.
