Fluid dribble after brake change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by oasmith, Jul 14, 2018.
  1. oasmith
    oasmith Junior Member
    42
    22
    So, not sure what happened here. I replaced my front and rear brake pads and rotors, and when i had the car back down on the ground and tightening the wheel lug, i head something dribble out from under the car. I immediately thought it would be brake fluid. It stopped after about like 5 seconds, and the amount was about as much as you could squeeze out of a wet sponge. Not much. I finished up the job, and turned the car on and it is operating totally fine. I backed the car up and got down to inspect the little puddle and it has no smell, no slippery consistency, and as far as i can tell without tasting it, it seems like just regular water. I had the car on for another 20 minutes going back and forth in the driveway, and no new drips occurred. Any ideas why a little bit would dribble out? Very odd.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Depends on which direction the dripping came from. Might be accumulated water, or the inverter coolant might be leaking somewhere. Just keep an eye on what's going on, as you drive.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Yes. BTDT. Usually from condensation that has accumulated from AC system. Changing height of front of car slightly changes where a puddle may form. Returning it to normal makes the puddle flow to it's normal drainage position.
  4. Leadfoot J. McCoalroller
    8,231
    7,735
    Pennsylvania
    2018 Prius c
    Agree with above. Almost certainly condensate from the air conditioner that didn't find its way out until you lowered the car.
  5. oasmith
    42
    22
    OK, thanks guys. It's been working fine.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Another vote for a/c condensate (water). BTDT
    Same scenario can occur after an oil change when ultra-light 0w-20 synthetic is still very clean and clear and back car down ramps to see a trail of drops...... OH NO! :eek: (performs finger/smell test) Oh, it's just water. ;)
  7. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
    FWIW....as you "push" the caliper pistons back into the caliper that pressure will raise the oil level at the master cylinder brake fluid fill point and perhaps the fluid will seep out/ past the fill container's cap.
    Some say to remove/ lower brake fluid from the container before you begin a brake job for this above reason.
    Else, since you tasted it (haha) AC condensation is good answer.
  8. Mendel Leisk
    42,165
    I think he says he didn't taste it.
    Apparently not oil, and coolant is a little "slicker" to the touch comparing to water, if I recall correctly? It wouldn't hurt to just taste it on a finger tip, then rinse your mouth. If it's coolant it would have a distinct sweet taste.
    I'm thinking AC condensate (water) too. Maybe OP can disclose location, weather conditions, and was he running AC?
    #8 Mendel Leisk, Jul 15, 2018
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Is your brake fluid reservoir overfilled?
    iPhone ? Pro
    Raytheeagle likes this.
