Fluids
Discussion in 'Prius v Main Forum' started by beachgeek, Mar 22, 2019.
Tags:
  1. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    I added windshield wiper fluid and noticed there appear to be four other places with fluid. One is clearly antifreeze and one indicates it has to do with the hybrid engine. Both of those are red. The two others are dark. One looks like it needs fluid. It's behind the one indicating hybrid. Is there a photo or drawing of what's what? I found a photo online but it doesn't tell me what's what. I found info in the manual but it doesn't tell me what's what.
  2. SamuelB
    SamuelB Junior Member
    32
    Orange County, Ca
    2016 Prius v wagon
    Mine are more pinkish. As I understand it there are two coolant systems...one for the engine, the other for the hybrid inverter system. Mine are just at the lower level marker so I got to investigate about filling them. Toyota says to use their specific coolant. I need to find out what most do so any suggestions would be appreciated. I was wondering if I could just add a little water to bring their levels up a little? Another reservoir will be for brake fluid. That is a brownish color.
  3. padroo
    padroo Senior Member
    2,763
    2,250
    If I remember Toyota coolant is premixed. I would not add just water unless it is an emergency.
  4. SamuelB
    32
    Orange County, Ca
    2016 Prius v wagon
    You might want to check and make sure you have the right coolant. From what I see Toyota Super Long Life Coolant is recommended for Prius. It is pink. If yours is truly red you may have the wrong coolant.
  5. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Someone posted a TSB that said either the old red that you mix with water or the pink premixed are both fine to use.
  6. SamuelB
    32
    Orange County, Ca
    2016 Prius v wagon
    This is the only one I can find that is labeled "Super Long Life" as recommended by Toyota. It is premixed. I have not found any undiluted that is labeled "Super Long Life." 1bb.jpg
    This one is undiluted but is labeled "Long Life." So is this the same as "Super Long Life?"
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    No they are different ;).
    Long life is the “red coolant” and is not the same:cool:.
    Always good to ask prior to use(y).
  8. SamuelB
    32
    Orange County, Ca
    2016 Prius v wagon
    Found this:
    "Toyota Long Life (red fluid) and Super Long Life (pink fluid) are completely different. Super Long Life (pink) contains sebacic acid -- a standard extended-drain-interval organic-acid technology for Asian car makes. Long Life (red) contains benzoate instead -- a more traditional standard-drain-interval corrosion inhibitor found in traditional antifreeze. It also contains phosphates -- preferred by Asian car makers for their instant corrosion-inhibition benefits. It doesn't contain 2-EHA, avoided by Asian car makers because of potential harm on gaskets and seals.
    Pink (Super Long Life) fluid is safe for newer Toyotas/Hondas but unsafe for older Toyotas/Hondas that have copper/brass/lead metals (such as OEM heater cores or certain aftermarket radiators) and it shouldn't be used in such older Toyotas/Hondas."
    Toyota red long life & pink super long life same? - Bob Is The Oil Guy
    So it would seem if your coolant is red it may be wrong
    Bluegrassman and Raytheeagle like this.
  9. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    ALL my fluids todate were put in by Toyota when they changed the oil so whatever color it is I want to believe it is ok. Now I'm looking for a service place but, in the interim, I'd like to know what those containers hold and if I am in imminent danger of suddenly having no fluid for something important.
    In another thread it says I should never have to worry about fluids. They are lifetime. Is that correct?
  10. bisco
    49,505
    incorrect, not sure what thread or who stated that.
    so, you get a maintenance schedule with your car that has all the fluid change intervals.
    you have engine coolant, inverter coolant, brake fluid
  11. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    If you are saying I should have gotten a maintenance schedule...maybe I should have but I don't believe I did. They told me to come in every six months until I got to 50,000 after which I'm on my own. I got to 50,000. I'd prefer not to go back to the dealer for a long list of reasons but I should know what I need to check and to look for in finding a replacement. I have four containers I can see under the hood (not counting the washer fluid). If there was a diagram for under the hood it would help.
  12. Mendel Leisk
    38,735
    That's the brake fluid reservoir, and I would leave that alone. Unless you're leaking fluid (which rarely if ever would happen), you do not want to "top that up". It's level will drop as brake pads wear, and come back up when the brake caliper pistons are pushed back in to accomodate new (thicker) pads. A perdiodic brake fluid replacement IS a good idea, but that's a different topic.
    Did you get two books? In the US there's an "Owner's Manual" and the "Warranty and Maintenance Guide". The latter has the maintenance schedule, in event-by-event format, which is a bit of a pain. If you're missing that booklet, you can download at Toyota Tech Info, in the "Manuals" section.
    I've done a summary of the 3rd gen Prius US schedule, which I believe is identical:
    #12 Mendel Leisk, Mar 27, 2019
    beachgeek and bisco like this.
  13. Mendel Leisk
    38,735
    Cobbled something:
  14. bisco
    49,505
    you missed the blinker fluid reservoir :p
  15. bisco
    49,505
    i'm sorry to hear that. most dealers are pretty bad, but every 6 months for 50,000 miles is one of the most egregious recommendations i've ever heard of.
    you're smart not to go back unless absolutely necessary.
    beachgeek likes this.
  16. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    Perfect. Thank you. No maintenance schedule book (but manuals for things I didn't have). I will download that. The original question did apply to the brake fluid container.
  17. SamuelB
    32
    Orange County, Ca
    2016 Prius v wagon
    Oh man....that one is kind of hidden. I almost didn't notice but mine was getting critically low. I hate to think what would of happened if air got in the line. I tend to signal early so I guess I burn through fluid faster
    Air_Boss and bisco like this.
  18. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    How about the harness smoke reservoir? Hybrid/electric cars must have a massive reserve.
  19. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Not wanting to rile up any arguments, I found the TSB regarding coolant interchangeability. I guess one is longer life than the other, but they are compatible.
