Fluttering / Drone sound at 40 mph+
Discussion in 'Gen 3 Prius Technical Discussion' started by speedyspaghetti, Jan 29, 2018.
  1. speedyspaghetti
    speedyspaghetti New Member
    Los Gatos, CA
    Hey guys,
    First time poster here - hoping to get some help on my girlfriend's Prius. We took the car to Portland over the Christmas break and I noticed a droning / helicopter sound coming from the car at 40 mph through highway speeds. I thought it was a wheel bearing, so I put the car up on jack stands when I got home and spun the wheels in neutral. It seemed like there was some crunching in the driver's side front wheel, so I got a new Timken bearing and replaced it today. The sound is still there, so I'm looking for some advice. Does this sound like a bearing issue? I'm fairly certain it's coming from the driver's side, but then again I was fairly certain that it was the one I changed... Could it be something else? Anyone dealt with this before? Car has 100k miles and is a 2010.
    Thank you!
  2. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    I would guess it’s a tire, try moving it onto a different axle and seeing if the noise moves as well
    2010 Gen 3
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Did the removed bearing have any slop or make any noise?
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Did you buy the hub or just the bearing, guessing hub.
    Speedometer cable? Debris in the brakes? As mentioned tire with a ripped belt?
    Raytheeagle likes this.
  5. Greg Grieve
    Greg Grieve Junior Member
    17
    Pa
    check air dam under front of car? may be loose and working like a reed valve.
    kc410 likes this.
