FM radio reception
Discussion in 'Gen 3 Prius Audio and Electronics' started by Filmmaker1225, Jan 20, 2013.
  1. Filmmaker1225
    Filmmaker1225 Junior Member
    33
    Santa Monica, CA
    I just wonder if there's a better replacement antenna out there, to improve FM reception. I'm driving 2010 4. Bought the car with 25K, so far have wracked up about 6 K driving. Love it, but would like to improve the reception one level.
  2. Jdh2425
    Jdh2425 Junior Member
    Baltimore
    Did you find any answers? I came here looking for the same thing.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    My megaladon mod has a 21” antenna in place for the factory Prius antenna. It’s one of those opposite & less desirable mods :eek:
  4. ASRDogman
    ASRDogman Senior Member
    8,057
    4,085
    Does the longer antenna improve reception?
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    You might want to take a look at the external antenna connection on top of the car. It unscrews (lefty-loosy) and there are captive notches in the rubber acting as a lock washer of sorts. If the connections aren't shiny and clean, then clean things up (including the socket on top of the car) and juice it up with some dielectric grease. If everything is in order topside, then maybe the other end of the cable into the control head (inside dashboard) is the problem.
  6. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    I got a pretty good improvement by replacing the short stubby antenna mast with a 31 inch mast
  7. ASRDogman
    8,057
    4,085
    31 inches is a bit long! I believe mine is 6 inches, but they make one that is 9 and I think 12.
    Thanks
