Fob and unlocking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lexidium, Jul 26, 2017.
  1. lexidium
    lexidium Active Member
    302
    143
    manchester
    My fob suddenly stopped opening and closing the doors but it still starts the car.
    I've checked the battery and that's fine; still lights up etc.
    It's not a smart key so no switch under the steering wheel.
    When I use the metal key, it locks all four doors at once so I assume the door locking mechanism is OK.
    I know about the chicken dance but no second key so can't do that.
    The main car battery is fine and not low.
    What else can I look at?
    Thanks
    Bob
  2. JC91006
    16,869
    8,617
    You should change the battery in the FOB. Starting the car in the keyslot does not use the fob battery, so that's why your car starts.
    windstrings likes this.
  3. lexidium
    302
    143
    manchester
    I checked the old one which was a full three volts and changed it anyway just to make sure.
    52,517
    check the 12 volt.
  5. lexidium
    302
    143
    manchester
    As I said in the original post, car battery is fine.
  6. bisco
    52,517
    sorry, i missed that. better than 12.4 volts when stone cold, and passed a load test?
  7. lexidium
    302
    143
    manchester
    Yes 12.6 cold.
    I just don't know what else to look at now.
  8. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Maybe there could be some problem in drivers power door lock? Using the mechanical key will just mechanically lock the drivers door. Do all the doors lock and unlock from lock switch inside?
    If that’s not the problem then maybe there’s a problem with the key. Or car has just somehow lost the programming memory from the key. You should get the second key anyways as it’s hard/expensive to get Prius working if you lose all the keys.
  9. bisco
    52,517
    stuck fob button?
  10. valde3
    2,002
    750
    Finland
    If the light on the key lights up when pressing either button they can’t be stuck.
  11. lexidium
    302
    143
    manchester
    No buttons stuck. Fob lights as it should.
    Mechanical key closes all four doors.
  12. bisco
    52,517
    i suppose something inside the fob could be damaged. i've even heard cleaning the circuit board can help, but idk.
  13. valde3
    2,002
    750
    Finland
    But does the switch on inside of the car lock and unlock all the doors?
  14. lexidium
    302
    143
    manchester
    Yes. Checked it this morning
  15. valde3
    2,002
    750
    Finland
    Then the problem in the key is the most likely problem.
  16. lexidium
    302
    143
    manchester
    I finally sorted it . . . . .
    Bought the mini vci cable from fleabay. Loaded the techstream software from the disk on to an older laptop with windows xp (32 bit).
    I tried all the methods online for loading it on to a windows 7, 64 bit but couldn't get it to work. It was very easy on the xp, 32 bit.
    Then followed the video on youtube (wouldn't have had a clue without that)
    and managed to program my key and another used key off another car (same make and model) so I now have two fully working keys.
    The only slight anomaly is that it tells you to press the lock and unlock buttons simultaneously for one second but that doesn't work. You have to do it for three seconds. It took me a while to suss that out.
    All in all, I've saved hundreds of pounds so very happy.
    Hope this helps others . . . . . .
    chaosphere likes this.
