Fob button replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 48mpg, Jan 26, 2016.
Tags:
  1. 48mpg
    48mpg Member
    193
    47
    florida
    I
    looking to buy the buttons under the rubber pad on my fob..
    anyone know where I can find them or part number..
    the lock and unlock buttons are missing on the fob, cant program a new (used) one until this one is fixed..
    thanks
      File size:
      122.9 KB
    51,141
    maybe ebay or amazon for a used one, then swap the buttons?
  3. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    They're part of the circuitboard, it's not an easy fix.
  4. 48mpg
    48mpg Member
    193
    47
    florida
    I
    I thought of that but a used one is around 50 bucks, don't want to waste the money, thanks
  5. bisco
    51,141
    have you taken it apart? will you have to unsolder them?
  6. 48mpg
    48mpg Member
    193
    47
    florida
    I
    I used to fix LCD TV's and you can use a heat gun to melt all the solder at once and lift the switch off then drop the new one in, its finding the right switch Im worried about..
  7. bisco
    51,141
    interesting, thanks! all the best in your search.
  8. laroleta
    laroleta New Member
    48mpg, any luck with the FOB? polmex australia has the external rubber buttons (not sure if this will help anyone)
    My lock button does not work on my FOB, the light does not turn on when i press lock and the rubber pad has been worn off (so switch is exposed). The other issue is that the previous car owner glued the remote shut.... Not having this button is preventing me from programming SKS functionality on my other remote... Any tips on:
    - Diagnosing what the problem could be? (all other buttons work and SKS functionality is intact).
    - In case i need a new button switch, has the correct replacement switch turned up?
    - How to open a seemingly glued remote without wrecking it?
    - Programming SKS functionality when the master key has a non-functioning lock button?
