FOB now must be inserted?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Freedom, Oct 19, 2017.
  1. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    Hi All, been some time since I was on here.
    Carmine is 9 years old! And I still love driving in her.
    Two days ago the car stopped recognizing the FOB via wi fi (not sure what the term is, lol). I have to insert the FOB to start the car. And I can press the buttons to unlock and lock the doors, but it doesn't work if I am just holding it in my hand.
    I've been to the dealership, had a new battery put in the FOB. No change.
    Any ideas? More of a nuisance than anything, don't plan to spend mega $$$ to have it fixed unless / until I learn more from all of you!
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,228
    5,912
    Columbia, SC
    Is this what happens when the little SKS switch under the steering wheel is turned off?
  3. Freedom
    535
    69
    Northeastern MA
    Oooh good, let me check! Because I just put air in the tires, could have hit the wrong button!
  4. TMR-JWAP
    6,228
    5,912
    Columbia, SC
    Would be pretty sweet if that ends up being the problem. If not, try doing a forum search using "sks switch". About a million hits come back, hopefully somewhere in there will be a solution that someone found.
  5. Freedom
    535
    69
    Northeastern MA
    YES! Problem solved! THANK YOU SO MUCH!!!
    Tideland Prius and Mendel Leisk like this.
  6. TMR-JWAP
    6,228
    5,912
    Columbia, SC
    Awesome. It's always nice when an inexpensive solution is found!!
  7. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Nice to know the dealership were on to it. LOL.
  8. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Ever consider reading through the owners manual?
  9. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    I know who you listen to on Saturdays ;)
