FOB response slow???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, May 23, 2015.
  1. JC91006
    16,885
    8,621
    It's on the low side. Fully charged it would be around 12.8 or higher. But with that voltage, it's not the cause of your problem.
    CR94 likes this.
  2. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    All
    Over the night, went out and check voltage in the Scangauge 2 in the morning, Scangauge 2 read 12.2V; do you think my original battery on the way out soon? if it does what do you guy think about this battery
    SLI51PAGM Duracell Ultra Platinum AGM Battery 2010 to 2014 L4 1.8L 325CCA Hybrid Prius Toyota Car and Truck
    • tem number: SLI51PAGM
    • Weight: 29.3000 lbs
    • Voltage: 12V
    • CCA: 325
    • Primary Applications: Car and Truck
    • Replaces: 46B24R, DUR-9A51P, S46B24R
    • Each Price: $179.99
      Available in-store only.
    52,578
    if that reading is on a stone cold battery with everything off, then yes, you need to replace it.
    a few here have tried the duracell. the jury is out, but no complaints so far, iirc.
  4. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Bisco
    you maybe right about stone cold battery, I am looking into buy a new battery, buy do you think that the reason my FOB response slow?
    Where all the jury? Labor day weekend? that NOT GOOD ;)
  5. bisco
    52,578
    i know, it's like a library around here.(n)
  6. bisco
    52,578
    a new battery may help. since you need one, might as well change it and see what happens.
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Bisco and ALL
    1. Can you guys tell me what is your voltage when you car stone cold with current battery please?
    2. Most you guys had Scangauge2 like me, 1 of 4 indicate of mine is Voltage for the battery, it still show 14.2V, is it 14.2v display is for system charge or Battery? if what I am thinking was correct then what setup for Scangaufe2 for battery only? anybody know please tell me.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Does your scangauge display a 12.x v value immediately when the scangauge display comes On after you start the car?
    Also, the display might drop to 12.x volts after you power off the car and just before the scangauge display turns off.
    That's your 12v auxiliary battery voltage without the HV traction battery online.
  9. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Xliderider
    1. Does your scangauge display a 12.x v value immediately when the scangauge display comes On after you start the car?
    Yes, 12.5V then 14.5V
    2. Also, the display might drop to 12.x volts after you power off the car and just before the scangauge display turns off.
    Yes, 14.5v then turn of it change to 12.9V then 12.6V then 12.5V the OFF
    Is my battery still good?
    anyway can Scangauge2 display 12v auxiliary battery voltage all the time like HV traction battery online ?
  10. CR94
    CR94 Senior Member
    2,783
    1,221
    Northwestern S.C.
    See post #21.
  11. xliderider
    8,140
    3,277
    Honolulu, HI
    The 12v auxiliary battery is charged by the HV battery DC to DC inverter when the car is Ready, so there is no way to measure what you are asking for.
    The fact that you got a 12.2v reading on a stone cold battery indicates that it's time to get a new battery. Your battery is 5+ years old, so it's not out of the question that it's on it's way out. Also, the dropping voltages after you shut down is another sign, it should only fluctuate maybe +/- 0.1v, not drop. That shows the battery isn't able to hold a charge well.
  12. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    XIiderider
    Very logical answer, I guess I am in for the new battery within this weekend.
  13. xliderider
    8,140
    3,277
    Honolulu, HI
    No one's brought this up in the thread yet, but cellphones can interfere with the fob.
    You can try to leave your cell phone far away when you try the fob for range. If the range improves, then your cellphone is most likely interfering with the fob.
    Does your decrease in fob signal range coincide with getting a new/different phone or other device?
  14. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Xliderider
    You just hit me in the head with your 2X4 knowledge; a friend of my just give me a Battery Jump Start and I left it in the trunk since Friday and that when start happen with my FOB slow response. I just take it out my car and I can open and lock my car 30ft away like before, then I put the damn thing back" Battery Jump Start" and guess what, I can not unlock my car within 10ft, took it out work again. Now everybody know and I am still looking for buy a new battery :) SH*T THAT NOT GOOD FOR LABOR DAY WEEKEND :) :(
  15. JC91006
    16,885
    8,621
    strange this detail just came out. I feel like we've been punked by a troll on memorial day
    #35 JC91006, May 25, 2015
  16. xliderider
    8,140
    3,277
    Honolulu, HI
    Interesting, the jump pack must be giving off either RF interference or a strong magnetic field that's interfering with the fob and antenna in the Prius.
  17. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    JC91006
    My head just got hit by you now; kkkkkkkkkk, you right "memorial day" NOT "Labor day" kkkkkkkkkkkkkkkkkkkkk
  18. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    EMI EMI AND EMI :(
  19. xliderider
    8,140
    3,277
    Honolulu, HI
    Better put some tinfoil in your underwear when handling that jump pack lol.
