FOB stopped working -- not opening doors or starting car
Discussion in 'Gen 2 Prius Technical Discussion' started by CIA_Guy, Aug 25, 2019.
Tags:
  1. CIA_Guy
    CIA_Guy Junior Member
    I have a 2007 with 3 FOBs. One has sat in a drawer unused for almost a year. When I went to use it, it wouldn't unlock the doors. It also didn't work to start the car (even when inserted in the slot). The other 2 FOBs work just fine. This one is essentially new, it's just been stored away. Battery in it is good.
    Is there something that can cause the car to "forget" one of the FOBs?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    What is the battery voltage?
  3. frankv64
    frankv64 Junior Member
    23
    Colonia NJ
    I would change the battery in it if you haven’t already. And check the voltage on your 12v battery. I have also 3 fobs for my 09 and they all still work. Two of them are sitting in my drawer for 4 years now
    iPhone ? Pro
    52,832
    has it ever worked? might just be incorrect fob. should work in the slot with a dead battery
    are the other two fobs working?
    Skibob likes this.
  5. CIA_Guy
    Main battery is fine -- both of the other FOBs work perfectly. This one worked fine when put away.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    So the voltage of the battery in the fob that is not working is?
  7. CIA_Guy
    New battery. I'll replace it again, but wouldn't it still work for starting the car if it is put in the slot? It's supposed to work there even when its battery is dead.
  8. CIA_Guy
    3V -- full CR2032 voltage. No change with new battery
  9. CIA_Guy
    Yes it worked and the other two are working. They are the only FOBs I have, so I haven't gotten them mixed up
  10. bisco
    52,832
    maybe a button is stuck
  11. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Do you carry one of the other 2 working fobs with you when you try to use it? Try walking up with just the non working fob and see what happens.
  12. CIA_Guy
    Nope. That's how I know it isn't working. Door doesn't unlock and car won't start (even with fob in the slot). I'm beginning to think it spontaneously died in the drawer.....
  13. Skibob
    2,912
    1,505
    Northern California
    Well, darn. Hoped I could help but I got nothing. Best of luck Amigo.
