FOB WON'T
Discussion in 'Gen 2 Prius Technical Discussion' started by deafelf, Jun 6, 2023.
  1. deafelf
    deafelf Junior Member
    Mississippi
    I have 2 FOBs. One I've used for 3 years. The other I've had stored. Well after much use The regular fob played out. So I bought a new case and battery. Normally the fob would start the car without being plugged into the socket. Now it won't start the car at all. The red light blinks when a button is pressed. The lock and unlock buttons work from 30' away.
    The extra FOG will start the car if it's plugged in only
    What can I do?
    DEF
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Did you transfer the RFID chip to the new fob case?
    #2 SFO, Jun 6, 2023
  3. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    There's a little rectangular block about a 1/4 inch thick you didn't swap out from old fob yet.
  4. deafelf
    Mississippi
    That did it. Don't know what I'd do without you guys. THANKS
    bisco and PriusCamper like this.
