Fog and Driving Lights
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PA Prius, Dec 15, 2015.
  1. PA Prius
    PA Prius Active Member
    763
    251
    SE Pennsylvania
    On the Advanced, are the fog lights on the outside corners and the driving lights in the lower grill? And the Base only has the fog lights, right? Are both the fogs and the driving lights decent, and not like the wimpy fogs on my '04?
  2. Tideland Prius
    16,445
    The foglights are in the lower air dam similar to the Gen 2. The outside corner lights are actually Daytime Running Lights. The DRLs are very bright. The foglights are about the same as the Gen 2.
    sfv41901 and PA Prius like this.
  3. PA Prius
    763
    251
    SE Pennsylvania
    Thanks. My understanding of Daytime Running Lights is that they are on all the time the car is on, but I don't see those lights on when I see Gen 3's on the road, or am I missing something here? I was thinking driving lights are additional bright lights that can be used at night when there is not oncoming traffic. When are these DRL's used? Sorry to hear that the fogs are similar to the Gen 2.
  4. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    The DRLs are on during daytime operation (headlights off) only if set up to be on.
    To further complicate matters, not all Gen 3 Prii were equipped with LED DRLs. 2010 and 2011 vehicles are not, whereas the 2012+ facelifted models are.
    PA Prius likes this.
  5. Tideland Prius
    16,445
    As xliderider mentioned, they're only available on Gen 3.5 models (2012-2015) and there is a DRL-OFF position on the headlight stalk IIRC so there is the option to turn it off.
    For reference, 2010-2011 models look like xliderider's avatar. The foglights are below the turn signals at the corner. There are no DRLs (Canadian models use the reduced power high beams as DRLs)
  6. Mendel Leisk
    40,574
    Here's the fog lights on our 2010:
    But they are really ineffectual; you have to turn them on/off several times to confirm they're actually throwing some light. Maybe on pitch black road they'd be some use.
  7. xliderider
    8,055
    3,222
    Honolulu, HI
    Or, turn the fogs on and off when facing a wall at about 20 to 30 feet. Glare (light) from the foglights present above the lowbeam cutoffs when the foglights are on. :(
    Mendel Leisk and PA Prius like this.
  8. xliderider
    8,055
    3,222
    Honolulu, HI
    OP, get these and replace your oem foglights with them, they are pretty much driving lights. I've got a pair on my Camry and they're great:
    Projector Fog lights (BOLT ON) finally! | PriusChat
    There are good output shots in the first post that show they have a nice cutoff and throw light out well without causing undue glare to other drivers.
    #8 xliderider, Dec 16, 2015
    sfv41901, frodoz737 and PA Prius like this.
  9. PA Prius
    763
    251
    SE Pennsylvania
    This is helpful, thanks all. I'm looking for a PIP, so I don't intend to replace the fogs on my '04.
