Fog Light Battery Connection Location
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jeremy Hernandez, Oct 25, 2018.
  1. Jeremy Hernandez
    Jeremy Hernandez New Member
    Washingon
    Hey all,
    Let me preface this thread by saying, I HAVE viewed all instructions on priuschat and on youtube for 2010 Prius foglight installation but realized they have different kits.
    My question is, in the instructions that came with my kit (instructions below) It says to connect the power wires to the battery. I have no clue where this connection would be on the front of my vehicle. I've been working on this project for 5+ hours and I figured it was time for help.
    Thank you so much,
    Jeremy
  2. Tideland Prius
    16,678
    The red positive wire? (with a circle at the end?). You can wire that to the positive terminal under the hood (There's red plastic cover with a big "+" imprinted on it). Take the cover off, unscrew the bolt, put the wire in and ensure the bolt is tightly screwed over it (otherwise you will get an error message when the engine comes on at start up).
    I can't remember where I put the negative but you can ground it by attaching it to any bolt on the body.
    Edit: Oh I see they're white in your case lol. That's weird. Umm, well determine which is positive and that can follow the instructions above.
