fog light inserts ?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by judoman09, Jun 18, 2026.
  1. judoman09
    judoman09 Junior Member
    24
    Coffs Harbour
    My 2019 Prius PHV doesn't have fog lights, however on Aliexpress i have found insert with the blank holes. I gather the fog lights are normally integrated with the vertical turn lights (?) however are there any aftermarket oval lights that would fit separately in there? As i've heard replacing the whole light assembly is a lot of money.
  2. judoman09
    24
    Coffs Harbour
    OR are the fog lights _only_ sold as an integrated assembly with the vertical lights? If that is the case ... can I get a separate control wire from the back of the light assembly , just for the fog lights, up to an aftermarket switch in my dashboard -- is that possible?
