1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Fog Light install Help Needed
Discussion in 'Gen 2 Prius Accessories & Modifications' started by shafi10a, Apr 21, 2019.
  1. shafi10a
    shafi10a Junior Member
    brooklyn
    So i purchased an OEM fog light kit and ive finally got time to install it. Issue is, i cant figure out which wire from inside to tap into. For my 2010, there are sufficient enough info online and i found it was a brown wire to tap into (DRL wire). However for this gen 2, its difficult to find proper info online. I tried to tap into the brown wire from inside ECU wiring. However, the fog light switch/button remains lit even when the car is off and locked. seems like it is getting consistent power which is not right. Anyone know which wire would be considered the DRL wire or the headlight wire? I tapped into the red and yellow as well and same scenario (constant power going to fog switch). Please help.
  2. MickyMatter
    MickyMatter Active Member
    260
    165
    Germany
    I don't know, but perhaps the wiring diagrams may help you (in the very end of this big manual file)
    Code:
    https://drive.google.com/file/d/17LZFTHg-OdnS1QjJnR4Qc7W3jsmAB4xS/view?usp=drivesdk
    SM-G950F ?
    SFO likes this.
Loading...
