Fog lights 12V & ignition wires location
Discussion in 'Gen 2 Prius Accessories & Modifications' started by car2lvr, Jun 9, 2009.
  1. car2lvr
    car2lvr Junior Member
    34
    North Burbs, IL
    Anyone know the location where I can tap a constant 12V and ignition on the driver side cabin? I know the constant 12V in the hood. I'm installing an aftermarket fog lights with the OEM bumper fog lights grill rings. Thanks.
  2. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Take a look at the CoastalEtech "Power Outlet Mod instructions:
    http://www.coastaletech.com/power_outlet_mod.htm
    The accessory plug circuit is limited to 15 amps so I suggest that you use a solenoid to supply the actual lamp current.
    JeffD
  3. Raider
    Raider New Member
    103
    I've worked on some cars where the accessories wires passing through the firewall were poorly installed and the wires were on the verge of grounding out on the chassis, possibly leading to an electrical fire.
    Instead of running a +12v lead from the interior to the relay to activate the fog light relay, I would recommend running a ground wire from your interior mounted switch. (Grounding the relay instead of sending +12v.)
    This will avoid looking for any other +12v sources.
  4. Raider
    Raider New Member
    103
    This will also keep the relay fuse and fog light power fuse together with the other fuses in the engine compartment.
  5. car2lvr
    34
    North Burbs, IL
    I found unused harness by the driver side vent with 18/16 gauge wire and it supplies +12V ignition. I just tap it there with a fuse.
