Fog lights/battery drain
Discussion in 'Prius v Accessories and Modifications' started by Thina, Aug 4, 2024.
  1. Thina
    Thina Junior Member
    So I added LED fog lights (that part isn’t the issue). They work fine. I tapped into the cigarette lighter as I wanted a back-up protection in case I forgot to turn them off.
    however since adding them I’ve had a weird 12v battery issue. I’ve needed the battery jumped once. When starting it, sometimes it starts fine. Other times it almost “forgets” how. While the 12v battery is on the tail end of its life, this was never an issue before.
    what gives? All headlight bulbs are LED.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,170
    6,321
    Texas Hill Country
    You could measure the off state parasitic draw. After a couple of minutes it should be 15-30ma assuming you have the hatch closed.
    Try a new 12v. They last a long time but eventually fail and without obvious pattern. I had one fail to Ready the car in a grocery parking lot after driving it for 30 minutes.
    Air_Boss and Thina like this.
  3. BiomedO1
    BiomedO1 Senior Member
    3,668
    1,900
    SacTown, Ca
    how was it wired? did you go through a relay or are you pulling all the current through the lighter circuit? If your not going through a relay, then your switch got hot and is partially closed or bridged. Ohm it out; it should be open.
    Air_Boss and tony_2018 like this.
  4. tony_2018
    tony_2018 Member
    227
    68
    the relay design is the one thing that needs to be looked at.
    Air_Boss likes this.
  5. Air_Boss
    Air_Boss Senior Member
    4,201
    1,185
    New Yawk
    I power my fogs behind a voltage-sensitive relay that triggers at 13.5 volts, which occurs is when the car is READY. Opens when car powers off.
