Fog Lights for Trim 4
Discussion in 'Gen 4 Prius Accessories and Modifications' started by munna, Jan 29, 2016.
  1. priusfan500
    priusfan500 Member
    94
    110
    Found this on a Japanese site...A fog light kit for Gen4 Prius using OEM Toyota parts..appears to consist of the left and right lamps, a new stalk/switch, and a relay. Only issue is that its for the Japanese market, a right hand drive vehicle, so its on the wrong side of the steering wheel.
    I did find what appears to be the correct part for the stalk/switch on Toyota of Dallas website..see photo below. I'm posting this for anyone looking to buy the fog lights from the dealer, as it appears there are other parts needed to make them work.
    Screen Shot 2016-09-28 at 3.59.47 AM.png Screen Shot 2016-09-28 at 4.29.21 AM.png
    #181 priusfan500, Sep 28, 2016
    4GP2ECOBP and mark27lim like this.
  2. marcpablo
    marcpablo Junior Member
    29
    31
    Carlsbad, CA
    Four Touring
    Just increase your tire air pressure by 4-6 psi and you will get the mileage back.
  3. MDNHW11
    MDNHW11 Junior Member
    2001 Prius
    If anyone knows of a seller for the clones, I would be interested.
    mark27lim and 4GP2ECOBP like this.
  4. mark27lim
    mark27lim Active Member
    108
    104
    singapore
  5. munna
    munna Junior Member
  6. mark27lim
    108
    104
    singapore
    hi i don't think they come with the switch. the replacement lever is very expensive and difficult to install. what i've done is fuse tapped the fogs and drl to turn on whenever the car is in ready. so they are always on. the only alternative would be to find a way through the engine firewall into the driver cabin and rig your own switch. if you are lucky there might be an available unconnected harness already in your car near to where the fogs are supppsed to be installed. good luck!
  7. Merrilea
    Merrilea Junior Member
    Pa
    What happened to the photo?
    dziadek1818 likes this.
  8. dziadek1818
    dziadek1818 Junior Member
    28
    poland
    I manged to find a 3rd trim stalk at aftermarket. The problem I have is - is it going to work?
    fog lights and stalk from 3rd trim on my version TWO Prius. Has anyone did such thing? :)
    Friend of mine did such thing. After strting engine fog lights switch on as DRL, changing stalk switch to actual DRL switches right away fog lights off.
  9. Mendel Leisk
    42,343
    Maybe just put in the cheapest fog lights you can find, and fugedabout getting them to actually work? It's all about looks, they're not very good, at least the OEM ones.
    RCO and dziadek1818 like this.
  10. dziadek1818
    28
    poland
    Actually i want to use them as DRL lights. In my country it is ok as long as beams are off.
    During the normal day I would use them as lights being on are obligatory here.
    Having version two without fog lights, i am thinking about changing steering wheel stalk and conect it.
    Read here that some guys applied outter switches but just wonder if in the theory stalk from 3/4 trim on two version would work.
    I am not electrician :/
  11. Mendel Leisk
    42,343
    I'd vote for just adding a switch in the dash. I know, it will look more like an add-on,but much simpler/cheaper, and it is an add-on. Just my opinion though.
    dziadek1818 and RCO like this.
  12. dziadek1818
    28
    poland
    Thanks Mendel. Have to think about it.
  13. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
  14. d4vr0s
    d4vr0s Junior Member
    Knoxville
  15. dml996
    dml996 Junior Member
    Spartanburg, South Carolina
    I just got a set delivered today from e-bay and plan to install within the next week
  16. scottymusprime
    scottymusprime New Member
    TN
    Did you do this install?
  17. Pager
    Pager Junior Member
    Stratford, CT
    Found these fog lights made by iJDMTOY SKU# 70-833. exact fit for 2016 Prius. Comes with harness but I tried to get wiring diagram and was told they didn't have one yet. Cost $263.99, two lights with harness.
  18. 18GolfCart4
    18GolfCart4 Junior Member
    2018 Prius
    Happy to keep this thread alive!
    While there's significant discussion in this thread (and perhaps others) re installing fog lights for Gen 4, I'm having trouble finding discussions from folks who went "full OEM" and actually changed out the turn signal stalk to include one that has the fog light(s) switch. Earlier in this thread someone stated that "the replacement lever is very expensive and difficult to install", but I'm up for the challenge. I have a 2018 Prius 4 (we liked the fog lights/wheels of the Touring, but wanted the HUD and moon roof) and would like to now add the fog lights.
    I've read about instances where, after swapping out the modular turn signal stalk, it's revealed that there's actually a relay already installed for the fog lights - it can be heard clicking when the OEM fog switch on the signal stalk is turned on/off (even the fog light indicator on the dash illuminates?). There's a thread about that here, but it's with respect to Gen 3:
    Fog Light Install w/ OEM Turn Signal Stalk / Switch | PriusChat
    As anyone successfully added the fog lights with the OEM stalk swtich on a Gen 4/2016-2018? If I do this, I'd rather not have an aftermarket "look" or non-OEM switch for the fogs. I'm not too concerned about the added expense of doing it this way, I simply want the install to be as "factory" as possible.
    #198 18GolfCart4, Aug 13, 2020
  19. loganmay9
    loganmay9 New Member
    2018 Prius
    Hello, I also wanted to revive this thread. Is there any update about the full OEM route? I bought the iJDM kit shortly after buying my car and installed it without any wiring, then later tapping into a fuse to let the DRL lights on the fog lights come on whenever the car is on. I have thought many times about spending some time to wire the fog parts of it up, but I don't really care to do so without some form of switch. Unfortunately, my 4 does not have any blanks though.
    Has anyone tried swapping the stalk with any luck at all? Or even does someone know of a kit that's similar to the Japanese kit posted a while back, but for US/LHD cars not RHD? Like18GolfCart4 I want to make this as OEM as possible, even if this means a lot of work. I got the Four I got because I valued the HUD and sunroof much more than the fog lights and rims. That said, if anyone knows if swapping the 4 Touring headlights with the 4 would give me the cooler Touring DRL in the headlight I'd be interested in that as well.
