Foglight Assembly Replacement - here's what I learned
Discussion in 'Gen 2 Prius Main Forum' started by Bluesman78, Mar 21, 2017.
  1. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    So I purchased a used prius with a broken foglight and I wanted to get it ready for inspection.
    I want to pat myself on the back here because I did this with no experience and almost no tools and no ramp/jack..
    Here's what I learned:
    1) Order an aftermarket part - mine costs $35 from amazon and included the bulb. Looked the same and fit in exactly
    2) I think I spent a few hours studying on how to do it (probably overkill), but I was really nervous
    3) It took me about 90 minutes to do it. Most of that part was the removal of the assembly. I ended up breaking the assembly to get it out. I was tossing it so why not. That was the hardest part. Also there was a lot of corrosion in the bulb attachment so I had a lot of trouble removing that blindly.
    4) I'm glad I did it, but I'm not looking forward to doing it again. I will buy lamin-x covers with the money I saved vs. having someone else do it. I couldn't really find another option for lens protections.
    5) Changing the bulb seems relatively easy.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Congrats, but isn't the inspection about pollution?
  3. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    No, depends on the US state. There is a safety component and an emissions component. Broken glass in a foglight could be a cause for failure depending on the mood of the inspector.
