Footwell lighting???
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Danger, Nov 11, 2011.
  1. Danger
    Danger Member
    175
    22
    Frisco
    Does the foot lighting go off or stay on all the time? I want to change the bulbs to LED but if they are going to stay on it might be distracting.
  2. duffasaurus
    duffasaurus Senior Member
    177
    38
    Charlotte, NC
    Re: Foot well lighting???
    The foot well lights stay on, but dim down in drive and reverse to just a soft glow!
  3. Tideland Prius
    16,680
  4. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    What trim line(s) have the foot well lighting? I was just reading through the online manual for 2012 MY and, under Sec 3-3 Using the interior lights, p. 353, I see that there are "foot lights (if equipped)" listed. Can someone confirm this for me? Thanks! :)
  5. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    My 2012 Five has them.... really nice effect too!
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The Four and Five.
  7. JJay
    JJay New Member
    123
    Vancouver, WA (near Portland)
    Our 2012 Prius Three has the amber lights under the dash. No other options but Solar roof.
  8. iDRiVaPrius
    iDRiVaPrius Junior Member
    So-Cal
    My Prius three without solar roof as them. One small bulb in the plastic pieces under the dash.
  9. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    What provides the color, bulb or lens? I haven't looked under there yet.
  10. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I have a standard package 3 and I have them.
  11. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    That's interesting. So it was standard on the 2010/11 Four and Five, but is now found on the 2012 Three. Can someone confirm whether or not the 2012 Two has it?
  12. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    The footwell lighting is already LED from the factory, it uses an amber LED.
  13. AZGeek
    627
    144
    63
    Arizona
    If it is LED then that is pretty cool that it has dimming capability. I am going to have to try to tap in to that to extend the footwell lighting to the back seating area.
    iPad ?
  14. Ytprius
    Ytprius New Member
    Az
    Does anyone know what led we could use to change it to blue? Led has to dim i assume. Also how to access it, for the switch. Thanks guys
  15. Ytprius
    Ytprius New Member
    Az
    Ok got some new white light bulbs for footwell lighting, and also glove box. Does anyone one have any insight as to how to access the bulbs to replace them? Hoping someone else has done this and can help
    j12piprius likes this.
  16. Tideland Prius
    16,680
    I've never looked on the driver's side, but the passenger side is very easy to remove. There's a plastic cover that is held by 3 clips, pull that out but do not pull completely out as the footwell lighting is attached. Locate the back of the LED bulb and simply unplug it.
  17. Ytprius
    Ytprius New Member
    Az
    Got it done. After getting the new bulbs and seeing how they just snapped in, it was a "snap". Didnt even have to remove and anything. Plenty of room to fit my hands behind replace with new ones. Now i have all white/blue lights in the interior and am at peace.
  18. AZGeek
    627
    144
    63
    Arizona
    ^^^ Cool. Pics?
    iPad ?
  19. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Which bulbs did you buy and from where? Thanks
  20. Tideland Prius
    16,680
    Nice! Are they any brighter? I wish it was a tad brighter in Drive. It's barely on.
