FOR SALE: -3 rear camber plate
Discussion in 'Private Sales' started by Sebvstien, Dec 18, 2018.
  1. Sebvstien
    Sebvstien New Member
    San Diego
    Selling -3 rear camber plate for Prius , fits 3rd gen model.
    Brand: Best Style Jp
    - never used, never mounted
    - comes with all hardware + instructions in Japanese (installation is pretty straight forward)
    $200 + $15 shipping (Anywhere in U.S.)
  2. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Ru selling to get a -6 one?;)
  3. Sebvstien
    San Diego
    Yupp
  4. Nopho4u
    1,007
    2,061
    Socal son
    I looking to do the same. From my calclutions i don't think -6 will e enough to fit 19x10.5 +30 in the rear. Think I need to go -8? What are ur thoughts?
  5. Sebvstien
    San Diego
    I was hoping to fit 17x10 +25 & +27
    With -6 , also have front camber plates coming in
  6. Nopho4u
    1,007
    2,061
    Socal son
    Hmmm as much as I wanna do 10.5 by 10j may work better.
    With -6
    According to my research 19x10.5 +38 could fit in the rear
  7. Sebvstien
    San Diego
    I’ve seen a lot of the Japan dudes run 10.5, however most of them have custom axles :\
    Do you have a pic of what 10.5 +38 would fit like?
  8. Nopho4u
    1,007
    2,061
    Socal son
    I don't have a image of 10.5 plus 38 but according to willitfit.com(now defunct website) i played around w/ specs and with 10.5 plus 38 it should fit w/ -6.
    So you saw the custom j-line rear axles as well I see. I was debating to go -6 shims for my next set up (currently only -3) or go extreme w/ the j-line premier and go -8 (believe u can order it as much as -10).
    Like you I want much more aggressive wheel set up then my current one. what are you running now? There's s local socal guy selling a set of ssr sp1 19x9.5 and 10.5 w/ 30 offset or so and i'm trying to fit them.
  9. Nopho4u
    1,007
    2,061
    Socal son
    18x10.5 -24 in rear w/ -10 degrees
  10. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    Why? Seriously.
    Burna J likes this.
  11. Greenteapri
    Greenteapri Active Member
    330
    388
    Cypress
    'cause 'Merica!
    Air_Boss likes this.
  12. Nopho4u
    1,007
    2,061
    Socal son
    you mean...
    'cause 'japan!
  13. MPGRaja
    MPGRaja Senior Member
    472
    1,687
    Corona
    You guys should starts a private conversation lol. Sale turned into tech talk :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::D:D:D
    But can’t wait to see what’s next for your Pri (y)
  14. Nopho4u
    1,007
    2,061
    Socal son
    Hey the convo is good to have publicly for anyone thinking to do more aggressive set ups!
    Sebvstien and MPGRaja like this.
  15. Sebvstien
    San Diego
    I believe the set up on that is
    18x9.5 +14
    18x10.5 -3 (had specs on his for sale post)
    ! You’ve gotta remember, these guys in JP aren’t only cutting their axels for camber, they are also raising/lowering it, and also probably shortening it to tuck those fat wheels !
    My specs:
    17x8 (stamped +31) ET+76.2 +20mm spacer
    17x9 (stamped +33) ET+63.5 +3mm spacer
    Reason why I say “stamped” is bc Rays stamped them as that, but I’ve read these wheels were sold with 20-30mm spacer so I measured them myself..
    #15 Sebvstien, Dec 26, 2018
  16. Nopho4u
    1,007
    2,061
    Socal son
    Those Japanese dudes always seem to be messing around with their specs.
    Do you already have the wheels that you want to put on the car or are you trying to add a spacer to this one
  17. Sebvstien
    San Diego
    Ended up rebuilding my current wheels.
    18x10 all around, currently waiting on my tires.. 205/40
    The wheels do poke a bit.. but if i can't get them to fit with some camber and fender pulling I will end up sending her to a body shop for some fender work. IMG_8077.jpg IMG_8079.PNG IMG_8200.PNG IMG_8201.PNG IMG_8651.jpg
    Johnsk93 likes this.
  18. Nopho4u
    1,007
    2,061
    Socal son
    What offset at is this with the -6 shim in the rear
  19. Sebvstien
    San Diego
    haven't done the math for offset yet... also no rear camber shim installed yet
  20. TooRice
    TooRice New Member
    Sacramento
    Are these still available?
