Force 2010 Prius screen on "Audio"
Discussion in 'Gen 3 Prius Accessories and Modifications' started by marrat, Sep 12, 2015.
  1. marrat
    marrat Junior Member
    47
    Netherlands
    I have a 2010 Prius with nav, I have a small problem with which screen is always on. I want the "Audio" screen to be shown at all times (unless I choose something else obviously), but I can't figure out how to make it work. If I go from "Map" to "Audio" for example, it switches back to "Map" after a few seconds. This happens with all options, other than "Audio". It seems the car doesn't want me to stay on that screen for some reason.
    If I remember correctly from my test drives with gen 2, there was an option to set the preferred screen. I can find no such option with my gen 3 car.
    49,429
    mine have always stayed on whatever screen i put them on. sounds like a malfunction.
  3. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    145
    53
    Chelmsford, MA
    Push the SETUP button, select General, then select Auto Screen Change and change it from On to Off. From the Nav System Owner's Manual Section 8 Setup, page 236. Available online at Toyota owner's manuals.
    marrat, Tideland Prius and bisco like this.
    49,429
  5. marrat
    47
    Netherlands
    Ah so easy, thank you.
