Force charge
Discussion in 'Prius v Technical Discussion' started by Owner, May 5, 2017.
  1. Owner
    Owner Junior Member
    I will be leaving my car for 5 months. Doing force charge I can get it to 6 bars but not 8. Is that normal. Should i be concerned with storing for 5 months?
  2. fuzzy1
    10,690
    Those bars are for the hybrid battery. It will be fine. Your problems will stem from the 12V battery instead.
  3. Owner
    Owner Junior Member
    I am using a battery tender for the 12V...everything I read was to force charge the hybrid until full
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    You read wrong. The charge level of the traction battery is not important.
    fuzzy1 likes this.
  5. fuzzy1
    10,690
    If it was down to the minimum of 2 bars, I'd still charge it up. But 6 bars seems just fine.
    Full charge is less than ideal for overall battery longevity. Somewhere near the middle is best, even though it won't last as long for any one trip. But the Prius traction battery doesn't seem to have a rapid self discharge, and snowbirds haven't been reporting problems.
    #5 fuzzy1, May 5, 2017
