force HV fan on with torque?
Discussion in 'Gen 2 Prius Technical Discussion' started by k1ngn0thing, Mar 28, 2018.
  1. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    I've got the custom PIDs installed but can't figure out how to control the fan.
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Great, glad you figured it out and have it working.
    The gen2 custom PIDs didn't included the fan control PID (maybe in the future), you will have to add it manually (like everyone else).
    This link should help get you started : Scanguage command to turn on hv battery cooling fan | PriusChat
    Raytheeagle likes this.
  3. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    not sure I completely understand. in the torque custom PID menu, I added the following in the "start command" field:
    00 00 07 e3 30 81 00 0n then changed it to 00 00 07 e3 30 81 00 6n for a fan speed of 6. what do I put in the stop command? is that is what's meant by "reply" or 00 00 07 eb 70 81? how do I even use this to toggle the fan?
  4. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    Try using the Hybrid Assistant app instead of Torque.
  5. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    doesn't let me put the fan on for anything less than 35 celcius. will adjusting the min temp to 30 make it run up to 30 and then from 35 on?
  6. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Not sure you read it completely, but here is a direct link to a single post in that thread. Hope it helps this time around.
    Scanguage command to turn on hv battery cooling fan | Page 2 | PriusChat
    For some reason I thought digesting two (2) pages of replies would be easier/quicker, but if you have the extra time or just feeling eager this thread is always worth perusing : Gen2 Prius: Custom PIDs for Torque (Android App) with formulas | PriusChat
    k1ngn0thing and Raytheeagle like this.
