Scanguage command to turn on hv battery cooling fan
Discussion in 'Gen 2 Prius Technical Discussion' started by epoch_time, Jun 24, 2012.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    This isn't true. I don't have a PHEV and my battery gets warm, sometimes above 120 degrees. And, the HV battery fan modification is a good idea for ANY Prius owner when operating in temperatures greater than 85 degrees.
    When you turn the Prius off with a high SOC or hot temps, the battery temp will rise. Having something to cool the battery after the car is off will definitely extend the life of the battery. Citations? Nope. I don't have any. It just makes sense that a cooler battery will last longer.
    Anytime your battery exceeds 104 degrees, your CCL starts going down. This means you will use more gas, use more meat on your brake pads and you will recoup less energy during braking.
    dave77 likes this.
  2. Pedaler
    Pedaler New Member
    Thanks for that. I see this is a pretty old thread, but I just tried that xgauge command and it worked, but would start up for a couple of seconds, then turn off, then start up again, and so forth.
    Is there anyway to modify the command so that it would be a continuous run?
    Under normal operation the fan runs steadily but at a speed too low to cool the battery.
    Thanks
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi Pedaler,
    You can try the command by lopezjm2001:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7
    0 [TH]XGAUGE[/TH][TH]TXD[/TH][TH]RXF[/TH][TH]RXD[/TH][TH]MTH[/TH][TH]NAM[/TH][TH]Notes[/TH]
    1 [TR][TD]Set Battery Cooling Fan Speed[/TD][TD]07E33081060n[/TD][TD]02EB24700581[/TD][TD]2001[/TD][TD]000100010000[/TD][TD1]SFS[/TD1][TD]where n is 0 1 2 3 4 5 6 (6 is max) shows ON when set[/TD][/TR]
    Let us know if it works for you.
    Vincent
    dave77 likes this.
  4. Pedaler
    Pedaler New Member
    Thanks Vincent. Sorry it took a while to get back to this. I tried the different code, with the same results as before (intermittent fan).
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I hate to start a new thread...but does anyone know the procedure to do the same using the Torque app?
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Anyone?
  8. tf4624
    tf4624 Active Member
    527
    51
    an option of continues run at any level 1-6 would be nice
  9. epoch_time
    epoch_time Active Member
    240
    113
    las vegas
    Yes here are the hv blower control codes for gen 2 prius.
    Codes tested on torque app 1.8.22 should be good for all versions.
    "Set Battery Cooling Fan Speed 1","SFS1","30810001","A","0","0","No reply req'd","7E3"
    "Set Battery Cooling Fan Speed 2","SFS2","30810002","A","0","0","No reply req'd","7E3"
    "Set Battery Cooling Fan Speed 3","SFS3","30810003","A","0","0","No reply req'd","7E3"
    "Set Battery Cooling Fan Speed 4","SFS4","30810004","A","0","0","No reply req'd","7E3"
    "Set Battery Cooling Fan Speed 5","SFS5","30810005","A","0","0","No reply req'd","7E3"
    "Set Battery Cooling Fan Speed 6 (max.)","SFS6","30810006","A","0","0","No reply req'd","7E3"
    Note prius hv cooling fan is variable speed.
    Hv cooling fan gets one extra volt of electricity per 10 mph road speed increase (approximate).
    Setting cooling fan speed via scanguage or torque app puts a fixed non-variable voltage on the blower motor.
    A scan/torq setting of 3 provides excellant battery cooling up to a road speed of approximately 45 mph.
    This setting of 3 inhibbits the fan speed at road speeds above 45mph.
    Better said normal prius fan cooling control (variable speed) runs blower faster at 45mph than the scan/torq setting of 3.
    But normal prius fan control tries to run hv blower (stealth mode unheard by driver) just below road noise and undetectable.
    Thus batteries get cooled best at hiway speeds under normal prius variable blower control.
    Or cooled very well with scan/torq setting 4 (fixed voltage) up to road speeds around 60 mph.
    Hope I explained this well enough . I will try and dedicate thread on prius fan EXPLAINED.
    Justdidit likes this.
  10. epoch_time
    240
    113
    las vegas
    For older scanguage fan control is
    Txd 07e33081000n substitute 1 through 6 for different speeds
    Rxf 057006810000
    Rxd 1901
    Mth 000100010000
    Nam sfs
    For newer scanguage ver 4.0+ use Rxf 02eb24700581
    I find entering several fan control commands works well.
    Example txd 07e330810003
    Nam sf3 fan speed 3
    Your next scanguage command
    Example2 txd 07e330810004
    Nam sf4 fan speed 4
    This makes it easy to change fan speeds as speed 3 is not enough sometimes.
    Then sometimes speed 4 is to much.
    I like to deselect speed setting before shutting down prius.
    This lets the prius select the much slower blower speed.
    And will make the blower relay contacts/switch last longer.
    I've forgotten to do this many times.
    Could toyota have chosen this slowest blower speed in attisapation of power down to make blower relay last longer sacraficing battery life?
  11. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    which fields do these values go in? first is start command? what about the rest? using torque
