Ford : C-Max Hybrid to have better fuel economy than Prius v
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by evnow, Dec 14, 2011.
  1. austingreen
    austingreen Senior Member
    13,659
    4,199
    Austin, TX, USA
    This is a 23kwh liquid cooled pack for a BEV. Its not a bad thing, y'all need to not think this is like the nimh battery pack in the prius.
    Toyota is having tesla do a similar modification to a rav 4 to make it a BEV. No plans that I have heard of to have an all electric conversion of a yaris. Magna, the supplier that worked on the EV1 developed most of the focus bev components, and this was done quickly to get to market. JCI-saft the company that does most of the car interiors and suppies EV batteries for ford's transit connect, has a EV battery layout that can be assmbled as part of a cars floor with seats that built for this interior. The volt uses a T, the leaf has its batteries under the seats and under the rear footwells. Given time and money Ford can definitely change the packaging but this was mostly a retrofit, and the battery supplier is compact power(LG chem) the same as the GM's for the volt.
  2. 2sk21
    2sk21 Member
    138
    22
    Teaneck, NJ
    There is a similar situation in my household. About 15 years ago, we bought a Taurus that turned out to be a really bad lemon. After that, my wife has decreed that until the end of time, we will never own a Ford again :)
  3. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    whatever it is, it is poor... As to the Toyota, as much as I know, iQ EV has battery below the car, not in the trunk... and Yaris HSD loses no trunk at all compared to normal version.
    It is called superior engineering, and why Toyota sells 700,000 hybrids per year and Ford sells... 30k-40k?
  4. spwolf
    3,156
    440
    Eastern Europe
    of course, it is plugin... compare that to Prius Plugin and are they really competing? :)
  5. spwolf
    3,156
    440
    Eastern Europe
    you need to be a bit more realistic when it comes to american cars... C-Max Hybrid competes with Prius, not with Prius v. It is small minivan, and 40% difference in trunk means they dont compete. Nobody is going to look at both cars and decide between Prius v and C-Max... if they need more space, they will get Prius v... if they need less space, they will look between Prius and C-Max.
    And Focus plugin competes with nothing with that trunk, it is obviously just for PR show. It is not going to compete with Volt, Nissan or Prius PHEV.
    If Ford doesnt want to invest money to make their cars lighter, and package their powertrain better, it is their problem, not customers. They will keep selling 10-15x less hybrids than Toyota and its their problem.
  6. austingreen
    13,659
    4,199
    Austin, TX, USA
    hmm. AFAIK the iq ev will not be offered for public sale, I would not compare that vehicle. I have not seen any details on the yaris hybrid, but it should be compared to other hybrids, not a full EV plug in, compare it to the c-max hybrid if you wish, but again that nor the c-max plug in, have the pack you showed. That is the focus bev as noted on the link.
    You are entitled to your opinion, but as I said I disagree about your segmentation, and I have not seen it in any of the automotive press. c-max is not a direct station waggon like the v, but both are trying to call themselves cross overs. No one would mistake the c-max hybrid for a minivan either, that would be the grand c-max sold only in europe. The cargo space for crossovers market normally look at things with the seats folded down, and the cars are similar here, you can read dimesnsions further up the thread. Only honda was foolish enough to go directly at the prius and it failed on the insight.
    people loved their ev1s with much smaller storage, and only 2 seats. Fords problem with the focus bev is that it is much more expensive than the leaf. Don't let the loud yelling about the cargo area fool you. Lots of folks have smaller trunks.
    It seems to me that the c-max hybrid is quite well designed. Its a mistake to only look at weight. Handling, acceleration, and fuel economy are all related to weight. We need to wait for a review to see about handling, but if it handles like the regular c-max that is an improvement over the prius and prius v, so not penalized by weight. The acceleration needs numbers, but again its better than anything in the prius family. Weight should reduce fuel economy, but according to ford, it is between the prius and prius v here, and the prius v is a lighter more aerodynamic car. The c-max engine and hybrid drive are likely more efficient.
    Ford simply can not compete in the japanese market. In the american and european market, ford technology is the same as toyota's. Toyota sells more cars in more segments, and has a big lead in the prius and lexus rx450h. Ford's goal is 100k units in 2013
  7. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    C-Max Hybrid will compete more with Prius v. It has the CUV form factor which a lot of people (including my wife) look for.
    Energi competes with PIP & Volt. But the one thing it has going for it over PIP & Volt is the CUV form factor. My wife won't even consider any car that doesn't have high seating.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Ford C-Max pricing to undercut Toyota Prius V
  9. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Looks interesting, I look forward to the real world reports on how it stacks up!
  10. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Focus and Prius are not in the same class.
    Ford is going the even smarter route of not using hybrids in the smaller cars and is going to focus on the DI turbo ecoboost for these cars. This will keep them cheaper and still provide great MPG.
    Next year the 1.0l 3cyl Fiesta will be here and should get 35/42ish numbers without batteries and barely any cost increase.
    Some of you will scoff at those numbers and point to Prius C and its far superior numbers. You can get a Fiesta for under 16k...that's something like 162k miles to make up cost difference. IE...significant.
  11. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Why not? Ok, 5 door version has a litle smaller boot, but 4 door version has bigger boot and is longer than Prius, there is also estate version with even bigger boot.
  12. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Focus is strictly 5 door or sedan now with latest gen in US.
    I suppose they should be since the Focus has bloated itself out of the compact category. Looking at the numbers they are almost identical in size with Prius having more passenger space and Focus having more cargo space.
  13. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    If you think the Focus EV trunk is bad look at the not even a real hybrid Malibu:
  14. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    BTW, for reference:
    Focus EV- 14.5 cu ft
    Camry Hybrid- 15.4 cu ft
    Prius C- 17.1 cu ft
    Focus also states 1.5cu ft of hidden space
    So its not nearly as bad as it looks.
  15. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    50 mpg Focus would be in the same class. I'd be driving one now instead of a Prius if Ford had spent the last four years developing and improving a Focus hybrid instead of dropping hybrids (Escape Hybrid gone) and spending time reinventing Toyota's lowest volume hybrid with an odd car which you can't buy for another year.
    Ah you mean don't compete in the best selling Prius and Prius C market. I'd call that terminally stupid and Ford's decline market share in hybrids would seem to be evidence of Ford's poor decisions. Of course, twice bankrupt (going for three) GM is not even in the game.
    Three years I'm in the market for a car again and it will likely be another Toyota, hopefully a plug-in with 50 mile EV range which would just about eliminate my car gasoline use. If Volt is still around and has improved, I'd consider one.
  16. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Decline?
    Fusion
    Fusion energi
    C-max
    C-max energi
    If you want to get silly they will have twice as many plug ins as Toyota.
  17. Trollbait
    12,417
    I think a Focus HV is still a possibility. It's just smarter for Ford to wait. Better to build their hybrid rep in other segments without the pressure of directly taking on the Prius first. By all accounts, the Fusion HV is a nice car. It surpassed the Camry HV in fuel economy when introduced. The new Camry surpasses it, but it appears Toyota will have less than a year of bragging rights before the new Fusion comes to market.
    Then there is the reality of resource availability. The Escape HV shortages of Aisin parts, so Ford has been moving hybrid production in house for this generation of hybrids. They now have four new hybrids coming out, two of which are plug in. Battery supply could be a limiting factor. Perhaps production can be increased for another hybrid model. Perhaps they don't want to risk quality control issues by increasing shifts. Or they want to hold production capacity in reserve in case a model takes off.
    We also can't overlook the fact that Ford has been climbing out of a financial hole from before the recession. Some exciting things have been coming from them, but they don't have the reserves to do everything right now.
    I think we'll see a Focus(based?) Prius fighter from them in the future. I also think we are more likely to hear about a Taurus or Flex hybrid first. Ecoboost seems to be their priority now. We were all hit by the recession, and it offers fuel savings without the cost of a hybrid.
  18. ProximalSuns
    1,877
    PNW
    Yes that is silly. Right now Ford is down to one hybrid, the Fusion. They never developed a hybrid to compete with the Prius, the biggest market for hybrids.
