Ford C-Max Struggles
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by sejinro, Dec 14, 2016.
  1. sejinro
    sejinro Junior Member
    23
    Los Angeles
    2014 Prius Plug-in
    I'm thinking of purchasing a used Prius Plug-in because I can't stand my Ford C-Max Energi. The lack of trunk space, squeaks and rattles, and limited 40 mpg are beginning to get at me. Having said all this, which year should I consider? 2013 seem to be priced right given my budget and mileage. Or maybe I should wait for a used 2017 in a year or so.
  2. Prodigyplace
    12,403
    11,681
    Central Virginia
    The 2017 Prius Prime has only 4 seats.
    Do you really need a Plugin? Perhaps the Prius Hatchback or Prius v might be better options. I usually get over 50 mpg and sometimes over 60 mpg with my Prius Hatchback.
  3. sejinro
    23
    Los Angeles
    2014 Prius Plug-in
    Thanks. Yes, I need a plug-in for the HOV access. I take it everyday for work.
    JacksonMs likes this.
  4. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    At 19.8 cu.ft., Prime has the same hatch space as the Energi just laid out differently. FWIW
    My door seals sometimes squeak but a quick wipe down with silicone spray gets 'em quite again. No rattles.
    Good Luck in your search!
  5. bisco
    51,140
    get a 2012 or 13 pip. all the advantages of prius, except the spare tyre. check out a prime, the raised deck makes the hatch a little smaller. but there is a lot to like otherwise.
  6. inferno
    inferno Senior Member
    1,072
    405
    I've had the PiP 2012 and have the Prius Prime Premium (middle trim). The incentives brought it down to be less than my purchase of my 2010 Prius.
    I have a few gripes (very technical) but love the car. It's a true Plugin vehicle where-as the PiP seemed like an experimental toy (that I still loved).
    If you can get get past that it's a 4 seater and you're looking for an economical plugin that feels much grandeur than one, that is the car to buy. I still have to test the Hybrid efficiency but I've been getting 26 miles EV easily in 20-40 F degree weather! Can't wait until it hits 60 (but winter just started lol).
    Oh yeah, the heat pump is amazing. I know this has been out on the volt, but it's niiiice...
  7. bisco
    51,140
    i didn't know the volt had it, will bolt have it as well?
  8. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    Nope neither will
