Ford Fusion beats Prius MPG!!!
Discussion in 'Gen 2 Prius Main Forum' started by KTPhil, Apr 13, 2009.
  1. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Ok// Don't have any info on 2009. Only older stuff.
  2. bac
    bac Active Member
    863
    52
    Pennsylvania
    I'm with you on ALL of that. I just don't like the way Ford is blurring the truth with their "sedan" advertisements. IMHO, Ford is attempting to FOOL the public into thinking that the Fusion gets better fuel economy than the Prius.
    They should just tout the car. It looks like it may be worth a look on it's own merits.
    ... Brad
  3. ETP
    2,801
    1,170
    Auburdale FL
    Ditto/ I was checking the Ford site out today and hope we will all be checking Dodge and GM also before long. I want the American car companies to kick ###. But I love my Prius man, LOL
  4. jon_lancaster_toyota
    jon_lancaster_toyota Nate Riesen
    120
    68
    Madison, WI
    .hdr { FONT: bold 12px verdana,arial,helvetica; COLOR: #ffffff; BACKGROUND-COLOR: #343434}.hdr1 { FONT: bold 9px verdana,arial,helvetica; COLOR: #000000; BACKGROUND-COLOR: #aba9a9}.hdr2 { FONT: 9px verdana,arial,helvetica; COLOR: #000000; BACKGROUND-COLOR: #dddddd}.hdr3 { FONT: 9px verdana,arial,helvetica; COLOR: #000000; BACKGROUND-COLOR: #ffffff}#ctl00_PlaceHolderAdColumnTop_ctl02_ctl00 { VISIBILITY: hidden}#ctl00_ctl29_ctl00_ctl03 { VISIBILITY: hidden} FUSION HYBRID CAMRY HYBRID 30/45-mph frequent-stop test 24.9 mpg 26.5 mpg 50-mph occasional-stop test 34.4 mpg 34.0 mpg 70-mph highway test 33.1 mpg 34.4 mpg
    I borrowed this from the April issue of motor tren. I want to point out that Fusion Claims some MPG, but they don't delivery on the claim. If you look at the specs for the Fusion vs. the Camry hybrid, you'll see that the two are nearly dead even in power out put, curb weight, and power to weight ratio. There is no possible way that the Fusion can beat the Camry Hybrid or Prius in MPG. Ford will get some good press for a month or two but as consumers that shop the two research the fusion, they'll find folks that can't hit the estimated MPG on the window. Looking at the shart above, keep in mind that Toyota's EPA estimated are 33/34 and look at their results above from Motor Trend. Toytoa's in their claimed range. Ford Claims 41/ 36? Look at what they really yield!
    Is there a Ford salesman than can give the answer to a consumer asking, "Why does Fusion out perform Toyota Camry Hybrid in MPG? "
    Salesman: "ford's better.....what will it take to earn your business today?"
    .hdr { FONT: bold 12px verdana,arial,helvetica; COLOR: #ffffff; BACKGROUND-COLOR: #343434}.hdr1 { FONT: bold 9px verdana,arial,helvetica; COLOR: #000000; BACKGROUND-COLOR: #aba9a9}.hdr2 { FONT: 9px verdana,arial,helvetica; COLOR: #000000; BACKGROUND-COLOR: #dddddd}.hdr3 { FONT: 9px verdana,arial,helvetica; COLOR: #000000; BACKGROUND-COLOR: #ffffff}#ctl00_PlaceHolderAdColumnTop_ctl02_ctl00 { VISIBILITY: hidden}#ctl00_ctl29_ctl00_ctl03 { VISIBILITY: hidden} 2010 Ford Fusion Hybrid 2007 Toyota Camry Hybrid POWERTRAIN/CHASSIS DRIVETRAIN LAYOUT Front engine, FWD Front engine, FWD ENGINE TYPE Atkinson-cycle I-4, alum block/head plus AC elect motor Atkinson-cycle I-4, alum block/head plus AC elect motor VALVETRAIN DOHC, 4 valves/cyl DOHC, 4 valves/cyl DISPLACEMENT 151.9 cu in/2488 cc 144.1 cu in/2362 cc COMPRESSION RATIO 12.3:1 12.5:1 POWER (SAE NET) gas: 156 hp @ 6000 rpm gas: 147 hp @ 6000 rpm elect: 106 hp (35 hp effective) @ 6500 rpm (elect) elect: 141 hp (40 hp effective) @ 4500 rpm (elect) combined: 191 hp combined: 187 hp TORQUE (SAE NET) gas: 136 lb-ft @ 2250 rpm gas: 138 lb-ft 4400 rpm elect: 166 lb-ft @ 3000 rpm elect: 199 lb-ft @ 0 rpm WEIGHT TO POWER 19.8 lb/hp 19.2 lb/hp TRANSMISSION CVT CVT SUSPENSION, FRONT;REAR Control arms, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar Struts, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar STEERING RATIO 16.0:1 15.6:1 TURNS LOCK-TO-LOCK 2.3 3.1 BRAKES, F:R 11.8-in vented disc & regen; 11.0-in disc, ABS 11.7-in vented disc & regen; 11.1-in disc, ABS WHEELS, F:R 7.5 x 17-in, cast aluminum 6.5 x 16-in, cast aluminum TIRES, F:R P225/50R17 93V Michelin Energy MXV4 S8 DIMENSIONS WHEELBASE 107.4 in 109.3 in TRACK, F/R 61.7/61.3 in 62.0/61.6 in LENGTH x WIDTH x HEIGHT 190.6 x 72.2 x 56.9 in 189.2 x 71.7 x 57.5 in TURNING CIRCLE 37.5 ft 36.1 ft CURB WEIGHT 3785 lb 3590 lb WEIGHT DIST, F/R 59/41 58/42 SEATING CAPACITY 5 5 HEADROOM, F/R 38.7/37.8 in 38.8/37.8 in LEGROOM, F/R 42.3/36.7 in 41.6/38.3 in SHOULDER ROOM, F/R 57.4/56.5 in 57.8/56.7 in CARGO ROOM 11.8 cu ft 10.6 cu ft TEST DATA ACCELERATION TO MPH 0-30 3.0 sec 2.8 sec 0-40 4.5 4.2 0-50 6.3 5.7 0-60 8.4 7.7 0-70 10.7 10 0-80 13.6 12.9 0-90 17.1 16.3 PASSING, 45-65 MPH 4.1 3.9 QUARTER MILE 16.4 sec @ 88.4 mph 15.9 sec @ 89.1 mph BRAKING, 60-0 MPH 126 ft 134 ft LATERAL ACCELERATION 0.79 g (avg) 0.76 g (avg) MT FIGURE EIGHT 28.6 sec @ 0.56 g (avg) 29.1 sec @ 0.56 g (avg)
    2010 Ford Fusion Hybrid vs 2009 Toyota Camry Hybrid - Comparison - Motor Trend
  5. jon_lancaster_toyota
    120
    68
    Madison, WI
    that didn't work. sorry. Perhaps I need to turn on the html or something'? chase the link I posted. You'll find the graphs on pages 4 & 6.
  6. ETP
    2,801
    1,170
    Auburdale FL
    Nice article.
  7. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    I know we've kicked all of this around before . . .
    The advertising really bothers me, too. I don't see the need for it. It seems the Fusion Hybrid is a really great car, though it might be a bit overpriced to compete well with the Prius. If the competition is the Camry Hybrid, then I'd like to see the side-by-side pricing of comparably equipped cars.
    Why not just say it is a great car, gets better gas mileage than any other 5-passenger car and is made in America? (Ooops, they can only say one of the three, right?)
    I hope Ford does very, very well with this car, but I just don't know who will pay $30K+ for a mid-sized car that isn't loaded with gadgets and doesn't get above 40 MPG, much less 50+. The Prius wins, hands down on all counts except rear seat hip and shoulder room.
